C5 ECM removal pics
Old Apr 15, 2007 | 01:10 PM
lavoieste's Avatar
lavoieste
Default C5 ECM removal pics?
Anyone have pics of the Removal of the ECM for a C5? I am right there at the ECM but I am not sure what to do to get it out.
Please no search ****'s I did a search and I find a bunch of C6 removals but they are not showing me what I see.
I am working on a 99 C5 6spd.
Thanks!
Old Apr 15, 2007 | 01:18 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
remove the 7mm screw so you can pull the fender out further, one on bottom and one on aft edge/middle
there is a plastic bracket that the tac module is attached to, unscrew the 3 or 4 screws and the 2 plugs/both 7mm(red/blue)
most likely the aluminum pcm case will be bonded to the plastic bracket, break it? no worries, $10 from GM
need a tune? contact Slowhawk in MA
Old Apr 15, 2007 | 01:57 PM
lavoieste's Avatar
lavoieste
That was it!
It is out and it was bonded and the bracket broke! would you the part # or the correct name for the bracket?
I am getting it sent out to Chuck COW to get it tuned...this all started because of the Steering Column crap! Oh well, I will get it tuned too.
Thanks!
Old Apr 15, 2007 | 03:03 PM
SteveDoten's Avatar
SteveDoten
sure, it's the 8 digit number cast into the part
Old Apr 15, 2007 | 10:47 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Glad you got it......
Originally Posted by lavoieste
That was it!
Thanks!
Glad you got it......Next, I'm gonna do a stat install post.....Watch for it...
Give a call any time you need help....(unfortunately, I'm always here...)
Chuck CoW
To C5 ECM removal pics
