passanger window
Old Apr 16, 2007 | 12:27 PM
03c5BiLL's Avatar
03c5BiLL
Default passanger window
is there any way to get the passanger window to go up untill i can get new motor i have try all the slam door tap on motor methods with no luck window is stuck down only about 4 inches
ty for all your help
Bill
Old Apr 16, 2007 | 12:45 PM
WirelessMan's Avatar
WirelessMan
6th Gear
Default C5 Passenger window Solution
Bill
I have a 2002 with the same problem, A gm mechanic told me that it has bad brushes on the motor, and to make it operate, he opened the door and while pushing down on the window button\ he hit the panel just above the speaker grill and the window went down.hope this helps!!!
Old Apr 16, 2007 | 03:31 PM
Autobot's Avatar
Autobot
My mom's grand prix had a similar problem, but the work gear was jammed on it.
What we ended up doing was removing the motor from the regulator which allowed us to pull the window up by hand and then hooked the motor back up so the window would not drop. This bought a few days until I could get the motor and put it in.
Old Apr 16, 2007 | 03:42 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
with the key powered on for accessories, try tapping the up button several times.
To passanger window
