Any idea?????????????
Old Apr 17, 2007 | 04:12 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Default Any idea?????????????
Any idea what it would cost to install the Z06 rear brake cooling ducts and screens on a 2000 FRC?
Old Apr 17, 2007 | 09:03 PM
cruisemon's Avatar
cruisemon
You doing the work or farming it out? Parts will run about $200. Add in another $300 - $400 for paint and finish plus labor to install. If all the work is farmed out, plan on $1000.
Charlie
Old Apr 18, 2007 | 10:41 AM
GUSTO14's Avatar
GUSTO14
Check out this Tech Tip... the instructions are excellent.
https://www.corvetteforum.com/techti...=209&TopicID=1
If you are very careful you should be able to install these without any expense except the kit. Most folks get a little nervous cutting into the rocker panel, but once you've made the first cut... the rest is easy.
Good luck... GUSTO
To Any idea?????????????
