Is their anyway to shut off the passenger side airbag on a 2000? Thanks!
Late 2000's had a key in the glovebox, if I remember correctly. Otherwise, you have got to buy the bypass kit and install it yourself. I don't believe a dealer will do it for you, due to liability concerns.
Ed
if there is no key switch in the glove box you might be able to just pull the fuse. I don't know for sure but it may be the easy and cheap way to shut it off. I leave my passanger side off all the time since my 4yr old is almost always my passanger.
508? Last 3 on VIN? Need last 6 #'s of VIN to determine Build Date. Mine is 102(026), built Aug '99. No Pass Airbag switch. Believe the switch was added at mid-year, after 1-1-00
I had the kit installed by an ex-GM mechanic. Not one delaership wanted the liability of messing with the airbag. Once installed, it is clean and does the job. Now my 6 year old son can ride with me top down!
Thursday February 3, 2000 - VIN 119656 JOB 019670 The plant began installing a passenger side air bag switch on all new 2000 C5s. The first C5 with the air bag switch was an ordered Torch Red Coupe with (AQ9) Black Sports Seats, Z51, Automatic with (G92) Performance Axle, (QF5) High Polished, Tilt Telescopic, (T96) Fog Lights, (UN0) CD Player, (T82) Twilight Sentinel shipped to University Chevrolet in Big Rapids, Michigan. The switch is located in the glove compartment and is operated with the ignition key. The indicator lamp is located on the center console near the active handling switch and the F45 selector switch (if equipped) .....Because of the addition of the switch in the glove compartment Corvette has changed the pouch for the owners manual from a zippered pouch to a non zippered pouch which closes with Velcro.
Per screw991le's post above: Thursday February 3, 2000 - VIN 119656 JOB 019670 The plant began installing a passenger side air bag switch on all new 2000 C5s.
Quote:
Originally Posted by 87SAM
120508, whatever date that is.
Originally Posted by 2KFRC5
Approx. 2-11-2000.
Thanks, still not positive how the date gets figured out of that. I was thinking that the last 4 or 5 digits were the number off the line, or do you have to refer to another document to get the date?
Friday February 11, 2000 your car started on the line.
