Check engine light
Old Oct 17, 2001 | 01:29 AM
Superj's Avatar
Superj
Default Check engine light
I ran the car up through 4th pretty quick tonight and drove it normally for another 15 minutes. Shut it down for about 10 minutes then started it up again and the check engine light came on.
I checked fuel cap. It seemed to be on tight. Removed it and put it back on. I've been using 93 Octane. Oil and temp was good and car ran fine. Seems like it may an emmissions type warning that tripped it.
Is there a way to manually reset it and see if it comes back on? I know you can do it with the LT-1 but that method did not seem to do the trick. I haven't checked the oil life with the tripometer yet. Any ideas?
Old Oct 17, 2001 | 02:44 AM
Superj's Avatar
Superj
Default Re: Check engine light (Superj)
Forgot to add, my Vette is a 2000 6 speed Coupe.
