trick flow ls1 heads
Old Apr 19, 2007 | 11:10 AM
jcote's Avatar
jcote
Default trick flow ls1 heads
does anybody run or heard anything about the heads good or bad?
Old Apr 19, 2007 | 12:04 PM
zeevette's Avatar
zeevette
Do a search. There's numerous threads with results of some tuners achieving over 500 RWHP on very streetable packages. I installed mine last fall, but had to redo the install because I used the stock rocker arms, and damaged the valve tips. It's now known that these heads will require the add'l purchase of roller rocker arms. Other than this drawback, they perform exceptionally well.
Old Apr 19, 2007 | 12:17 PM
DVS 99's Avatar
DVS 99
Why is the rocker arm change required?
Old Apr 19, 2007 | 01:06 PM
Tuner@Straightline's Avatar
Tuner@Straightline
We love these heads.
Old Apr 19, 2007 | 01:19 PM
Pwrtrip75's Avatar
Pwrtrip75
Either shody engineering or a reason to spend more money?
Old Apr 19, 2007 | 03:53 PM
zeevette's Avatar
zeevette
Uh, I already gave you the reason. The stock rockers will wear cups in the valve tips, and would eventually lead to a dropped valve. This is not as big a deal as it seems, because the stock rockers are prone to failure anyway, and it'd be a shame to build a nice high performance motor, and have it eat a bunch of those little roller bearings that the stock rockers have a tendency to crap out.
Old Apr 19, 2007 | 04:03 PM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
http://forums.corvetteforum.com/show....php?t=1651483 I PICKED UP 70 RWHP ...
To trick flow ls1 heads
