Have I miss this
Old Apr 19, 2007 | 01:41 PM
rkort's Avatar
rkort
Default Have I miss this
How long should you let you car warm up before you put it in gear, and then before you hit the petal, what the group feelings
Old Apr 19, 2007 | 02:52 PM
drbvac's Avatar
drbvac
As long as the oil pressure is up to running pressure it should be fine
Old Apr 19, 2007 | 02:57 PM
jbauch357's Avatar
jbauch357
Drive it while keeping under half throttle and 2,500 RPM until your oil temperature gets to 180 degrees - then get on it!!!
Some people let the car warm up to operating temperture while parked then go romp on it - this is no good cause when the car is just sitting the drivetrain isn't warming up along with the motor.
Others will look at the coolant temp as an indicator - I don't do this either because it doesn't give an accurate representation of what the actual motor temps are.
Old Apr 19, 2007 | 09:02 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I tend to agree with jbauch357. Take it easy till the oil temp gets up there first. No sense putting a severe load on things when they haven't reached normal operating temps otherwise you might be wishing you had waited, after the damage is done.
Old Apr 20, 2007 | 07:39 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Old Apr 20, 2007 | 08:20 AM
I start the car up and move on out. I just limit the throttle until the car fully warms up.
Old Apr 20, 2007 | 08:57 AM
R Devil's Avatar
R Devil
Idling is a waste of time and fuel.
Old Apr 20, 2007 | 09:01 AM
02MillenniumVette's Avatar
02MillenniumVette
These cars were built so you can start them up and drive, not wait for it to warm up like the older cars 20 years ago.
To Have I miss this
