Why do ported heads cost so much?
Old Oct 17, 2001 | 12:31 PM
2thDr's Avatar
2thDr
Default Why do ported heads cost so much?
I've found stock heads for $500-$700. But ported heads go for $2000-$2500. Why is that? Are they THAT difficult to port? Especially using a CNC machine?? I mean, once they have done the flow testing on a set of heads and put that program in the CNC machine, all it has to do is cut each head the same from then on, right?
[Modified by 2thDr, 10:50 AM 10/17/2001]
Old Oct 17, 2001 | 12:47 PM
Walt Donovan's Avatar
Walt Donovan
Default Re: Why do ported heads cost so much? (2thDr)
Generally, you pay for the time on the flow bench and the resulting port shape, as well as the actual cutting. Sure, CNCs cut a lot faster than a Dumore but the machine payments are a lot higher too.
Old Oct 17, 2001 | 01:03 PM
Matt Gruber's Avatar
Matt Gruber
i ported mine to save money. took 30 HOURS!
I did not bother to test them on my flow bench. i spent enough time!
Old Oct 17, 2001 | 01:23 PM
Avanti's Avatar
Avanti
Default Re: Why do ported heads cost so much? (drives61)
It's obvious you've never ported anything! Can you say labor intensive? Those who think porting aluminum is a bear or expensive, never lived in the age of cast iron heads! Be thankful for aluminum. Trust me on this one, I know what of I speak :yesnod:
Old Oct 17, 2001 | 02:58 PM
2thDr's Avatar
2thDr
Default Re: Why do ported heads cost so much? (Avanti)
If you'll read my post again, you'll see that I'm not talking about hand porting.
Old Oct 17, 2001 | 03:44 PM
C5Noir's Avatar
C5Noir
I believe that much of the cost stems from the EXREMELY expensive equipment they use, i.e. CNC Machines, Flow Benches and hundreds, if not thousands of hours in getting the ports, combustion chambers, runners, etc essentially perfect for the applicaton they're coming up with. Plus, the machinists/tuners gotta eat too :D
[Modified by C5Noir, 1:45 PM 10/17/2001]
Old Oct 17, 2001 | 04:18 PM
Moundir's Avatar
Moundir
Default Re: Why do ported heads cost so much? (C5Noir)
eat what? Fois Gras and Filet Mignon :lol:
Old Oct 17, 2001 | 05:01 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Why do ported heads cost so much? (Moundir)
It's a rip :smash: :smash: :smash: :smash: :smash:
Old Oct 17, 2001 | 05:52 PM
Chris@SD's Avatar
Chris@SD
Default Re: Why do ported heads cost so much? (John Shiels)
Used CNC Machines go for half a million dollars that can handle porting a head! You are paying for the machine. A Pentium processor is probably $5 in material costs. The machine to lay micron archetecture and the engineers they pay to design and improve the chip is what you are paying for. :)
Old Oct 17, 2001 | 06:08 PM
C5 YA's Avatar
C5 YA
Default Re: Why do ported heads cost so much? (2FST4U)
As a plastics engineer, I have overseen about 50 molds. Same concept. You buy a block of aluminum and then put it into a CNC machine, add the program and go. Then you inspect the pieces & heat treat. Inspect and then polish & polish.
:cheers:
Old Oct 17, 2001 | 08:10 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Truley good heads that are CNC machines are always followed up on by hand.
With LS1/6 heads, your paying for many things, including supply and demand.
Old Oct 17, 2001 | 10:28 PM
John Shiels
Default Re: Why do ported heads cost so much? (kewlbrz)
CNC heads with no hand work do look like half a job.
Old Oct 17, 2001 | 10:35 PM
Peach's Avatar
Peach
Orlando Events Coordinator
I have some heads with 2000 miles on them, make me an offer
Old Oct 18, 2001 | 01:58 AM
kewlbrz's Avatar
kewlbrz
Default Re: Why do ported heads cost so much? (Peach)
stock ls1 heads are on ebay and elsewhere all day long for 200 - 300 bucks a pair.
To Why do ported heads cost so much?
