getting louder exhaust without headers?
Apr 19, 2007 | 05:44 PM
what can i do to a C5 Z06 to make it louder besides a different catback and a X-pipe?
i have Bassani Street comp catback and a magnaflow X-pipe going in, what else can i do?
here is the tricky part, i have to keep some kinda cats in place
opinions? Magnaflow direct replacement cats
http://www.performancepeddler.com/de...CT_ID=MAG93988
Apr 19, 2007 | 06:26 PM
Is the Bassani exhaust installed? If not, you may want to see how you like it because you might not want it any louder. I had the Bassani cat-back on my C4 and if the C5 version is similar, it will be loud enough - trust me.
Apr 19, 2007 | 06:40 PM
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
Try the H/C mod. It really cranked up the volume on mine.
Apr 19, 2007 | 07:15 PM
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
I agree with try what you have. The Bassani is pretty loud. Other wise you may want to consider the A & A muffler bypass. Under 1800 RPM the exhaust is pretty normal. At 1800 and up, you are pretty much bypassing the mufflers and running nearly straight exhaust. Cost is usually less than a hundred bucks and is a great mod for the money.
Apr 19, 2007 | 07:23 PM
the bassani is on, and i would still like it louder,
i dont really want to cut the stock mid section in half to add a x-pipe, thats my primary concern right now
Apr 19, 2007 | 08:17 PM
Cruise-In VIII Veteran
Wow, I have the Bassani street/comp system as well and I can't believe you want it louder. I will say that after I added the complete Dynamax header, hi flow cats, and x pipe system to the mix it was even louder that with the cat back alone. It really turns heads now.
Apr 19, 2007 | 10:39 PM
Why don't you want headers? You can get them with high flow cats.
Apr 20, 2007 | 03:26 AM
St. Jude Donor '11-'12-'13-'14-'15
I used 3" Thunderbolt Cats on my Header install from performance-curve .com... I had bungs welded into em... $55.00 a piece!
Part # - 415300
Length - 11"
Body - 4" Round
Inlet - 3"
Outlet - 3"
Brick Type - Metallic
Material - 409 Stainless Steel
with Face... if you're on the fence then get some inexspensive ones like I did... and just try em out.
Apr 20, 2007 | 08:00 AM
Apr 20, 2007 | 08:17 AM
Electric cutouts will do the trick.
Apr 20, 2007 | 10:03 AM
Quote:
Originally Posted by
JDs00PewterCoupe
Apr 20, 2007 | 11:14 AM
I have the cut outs and it doesn't get any louder. To see pics check out my corvette photos to left.
14946 ,
bassani ,
borla ,
c5 ,
corvette ,
exhaust ,
exhuast ,
headers ,
louder ,
make ,
pipe ,
stock ,
worth
