Reverse lock out on 6 speed ?
Old Apr 21, 2007 | 12:18 AM
nmbsun's Avatar
nmbsun
Default Reverse lock out on 6 speed ?
By accident I shifted to 5th a little to far and it went almost in reverse until I heard the gears grinding. This is the first time I have Ever done that with any manual tranny. Could anyone explain why the lock out was not working? The computer ? What ?
Old Apr 21, 2007 | 12:25 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I do that more than Id like to admit.
Old Apr 21, 2007 | 12:03 PM
corvettebob1's Avatar
corvettebob1
No lock out.
Old Apr 22, 2007 | 08:27 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
It's possible the reverse inhibit solenoid is either unhooked or bad. It should lock out reverse above 3 mph. On my '99 its located on the top side of the transmission.
Old Apr 22, 2007 | 10:59 AM
Oldvetter's Avatar
Oldvetter
Even with the electronic lockout NOT working, it takes like 15 pounds of force to overcome the "mechanical" lockout. That just about takes two hands! What are you guys doing?
The electronic lockout solenoid only lets you engage reverse when it is on. If it is not working, you have to overcome the "mechanical" backup.
Unless, somehow, your electronic lockout is on all the time. Never heard of this, and I would think that it would overheat. You could test for this by finding the fuse and pulling it.
Old Apr 22, 2007 | 11:42 AM
JC in XTC5's Avatar
JC in XTC5
FYI - When shifting quickly between gears, I've heard and had it happen to me where you grind. I believe it's more related to the syncro's than going into reverse, but I may be wrong. Nonetheless my reverse lockout continues to work.
Old Apr 22, 2007 | 02:15 PM
corvettebob1
Ok, a reverse lock out would require you to lift a t handle or ring on the shifter.
Is there one there?
A reverse inhibit can be overcome with about 15lbs of force this is about 1/10th the force that can be exerted on a shifter during rapid shifting.
Old Apr 22, 2007 | 08:06 PM
Sick Z06's Avatar
Sick Z06
Is there one there?
Spirited driving has been known to be performed in a state much like fight or flight. Which will raise your body's adrenaline level and strength.
Trust me I've done the whole bump and grind on reverse more then I'd care to admit in numerous vehicles.
To Reverse lock out on 6 speed ?
