Need Help w/Ext Temp & HVAC
Is there anyway that the sunbeam sensor could be affecting it?
My AC does the same thing sometimes...the light will blink on and off and the outside temp ALWAYS reads way hotter than it really is outside? I didn't realize that the computer wouldn't let the AC blow cold if it "thought" that it was below a certain temperature.
The reason I bring up the sunbeam sensor and not either of the other ones is that I've already replaced them both?
Thanks,
Donnie
Thanks,
Donnie
Try this ..... turn OFF the car ....
Disconnect the sensor. When you turn the car on you should get DTC B0333 Outside Air Temp Sensor Open, and the temp display should default to 65*F (or 69 .... I forget which) . This would tell you that there are no shorts in the wiring harness/connector.
Short the sensor connector - this won't blow anything. You should get DTC B0332 Outside Air Temp Sensor Short to Ground, and the temp display should default to 65*F. This will confirm that there are no random impedances in the circuit.
I'm suspecting that there is corrosion in the connector, the second test will probably give you a temperature display different than the default and no DTC.
To ensure the sensor itself is good .... measure the impedance of the sensor itself. At 68*F, it should measure 12,493 ohms. At 86*F/8,056 ohms, 104*F/5327 ohms. That should be enough to verify it's within its expected range.
The sunload sensor doesn't affect the displaye4d Outside temperature .... the idea of the sunload sensor is to help the HVAC computer determine how much fan and cold air to deliver to mainttain cabin temperature. For example say you want the cabin temperature held at 70 degrees .... On a bright sunny day where it is ... say 85 ouside, the HVAC unit will deliver more cold air than it would if it was nighttime and 85 outside.
The temp range compared to what it really is, is more like if it's 100 degrees out side...my little display will say like 118!
It's not so much more than I'd like to know what the temperature is outside and the system probably works really well when it's working properly. Most of the time the AC will shut off when the car is first started up in the middle of a hot afternoon when I'm getting off work. The first couple of stop lights that I sit at if it's over 100, the AC will always kick off when I sit at idle in gear for over 10-15 seconds...I notice it because of the slight change in idle speed.
I'll unplug that sensor and spray it out with some electrical cleaner, then check the resistance....how should I short it out though? sry
Donnie
Donnie
Your A/C compressor is shutting off ??? Sounds like you may be low on refrigerant. Have you checked the car for DTC data ??? If the PCM (which actually controls the A/C compressor clutch .... the HVAC "requests" the compressor on .... the PCM "commands" it on....) is refusing to engage the compressor clutch, or is disengaging it when the HVAC wants it on, the PCM will set one or more DTC.
You need to display your DTC data. If you don't know how to do it go here ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
When the AUTOMATIC display completes it will enter MANUAL mode. In that mode display and write down what codes you have.
A code looks like this ...... P 1234 C
The first letter will be either a P, B, C, or U ..... indicating which system the code is for.
The following 4 numbers are the code
The last letter will be a C or an H (sometimes both).
Post the ENTIRE code (as in the example ..... P1234C), and list ALL the codes found.
As far as the ext temp reading goes, is it more accurate when you are moving, and away from hot concrete streets? Mine always read high in stop-n-go city traffic, but when I get on the highway at speed, it comes back down. The street surface may be in the 120*-140* range, which can affect your readout at a stop.
Like BlackZ06 said, you need to check codes. Also you need to check and properly charge your system.
I went out and checked my codes again today and there were none in the HVAC part but here the are the other ones...
U1255 H
U1016 H
U1160 H
U1088 H
U1064 H
U1096 H
U1040 H
B2583 H
B1001 HC
B0521 H
B2172 H
B2177 HC
B2197 HC
B2187 H
C1222 H
C1226 HC
C1233 H
I know that the "U" codes are loss of communication to everything codes lol...but I haven't cleared them in a long time until today.
The "C" codes are due to me either needing to replace my actual wheel hubs or I'm gonna try and replace the connectors on the back here eventually and see if that fixes the codes first...they're both due to excessive wheel speed variation on RF and LF with the RF one also saying that the circuit is open or shorted...
Now I'm pretty sure that the B1001 and B2583 codes are due to the fact that I still don't have my original PCM in the car and have to do with the SRS system correct?
The other "B" codes have to do with the issues that I've been having with my driver's side seat and that along with this AC ISSUE and the P0327 code (front knock sensor circuit) are the on-going problems that I still don't know how to figure out...?
Thanks for any suggestions,
Donnie
I still haven't gotten enough time to let the car sit while I'm not at work long enough to blow out the condenser and radiator...there does seem to me quite a bit of hair and very fine debris stuck in the fins of the condenser and radiator but I had been more checking for big stuff such as a plastic grocery bag or something to be blocking air flow....?
I might try disconnecting the battery and pulling the PCM fuse again and see if it makes any difference on the codes?
I just had the AC refrigerant level checked and topped off like 6 months ago but I'll go in and have em' check it again just to be sure.
Thanks again!
DZ
If you have a DMM (digital multi-meter) set the **** to the lowest ohm setting (look for the "Omega" symbol ... look like a circle open at the bottom with a little "base" at the ends of the break in the circle) ....
and measure the sensor, just hook the two cables (probes) into the sensor connector .... then read the ohms and compare them ....
At 68*F, it should measure 12,493 ohms. At 86*F/8,056 ohms, 104*F/5327 ohms ......
try both your old and new sensors ... they should theoretically read the same impedance at a given temperature ....
