C5 and a Low Profile Jack
Old Apr 22, 2007 | 12:06 PM
JOEY P's Avatar
JOEY P
Default C5 and a Low Profile Jack
Along with pucks is a low profile floor jack good to use to work on a c5 because im thinking of buying one...Thanks
Old Apr 22, 2007 | 03:21 PM
CHJ In Virginia's Avatar
CHJ In Virginia
It depends on several things. Is your car set at stock ride height or has it been lowered ? How low a profile is the jack, it varies a lot from manufacturer to manufacturer. Stock ride height allows most low profile jacks to work with a puck. If the car has been lowered, it's best to take a measurement to the frame and compare it to the height of the jack you are considering and add puck thickness to see if you have enough clearance.
Old Apr 22, 2007 | 06:54 PM
MagRed_00's Avatar
MagRed_00
Default Here's what I have...
I just bought an AC Hydraulics 13DLQ jack. It will go under the front of the car, with the rubber lifting pad, and pick up a stock hieght C5 no problem. I also got the 3000-GS1 jack stands that have a 4" diameter rubber pad on top. These parts can be found at asedeals.com or drivewerks.com but they are not cheap. I spent about a grand on the jack and 4 jack stands.
Two weeks ago I was using a "low profile aluminum" racing jack and it let the car down way to fast (could be user error). It then caused a cheap jackstand with the curve in it instead of the rubber flat top to flip sideways and the car shifted over onto a buddies hand . The jackstand collapsed so he didn't lose any fingers, but it opened my eyes to eating some mod money to get the right tools.
The AC jack is very controllable and I am sure someone can post a pic. Good Luck!
http://www.ac-hydraulic.com/Default....wproduct&id=44
for the jack
http://www.ac-hydraulic.com/Default....wproduct&id=89 for the stands
Old Apr 22, 2007 | 07:08 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I just saw a very low profile jack at a Costco for $99. Looks perfect for our cars.
Old Apr 22, 2007 | 11:55 PM
Brad@RevXtremeAutoSports's Avatar
pep boys had a nice one for 59 dollars.
Old Apr 23, 2007 | 12:28 AM
jbauch357's Avatar
jbauch357
you may still have a problem getting under the car with a low-profile jack - but you can build wood ramps for $15 that will allow almost any jack under the car...
Old Apr 28, 2007 | 10:33 AM
JOEY P's Avatar
JOEY P
Thanks for all your answers...
Old Apr 28, 2007 | 01:46 PM
tellefan's Avatar
tellefan
I bought one of these. It also works great on a four post lift. David
http://www.homier.com/detail.asp?sku...Detail%20Click
Old Apr 28, 2007 | 02:04 PM
Mick_C5's Avatar
Mick_C5
i used 2x10`s one 24 inches and on top of that another 12 inch piece screwed down, like steps. works like a charm and you don`t need a expensive racing jack. race ramps are nice to have as well.
Old Apr 28, 2007 | 02:34 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Me too
I have a regular 2 1/2 ton jack that I used on my other cars. I just pull up on a couple 2X10s, and it's good to go.
the money I saved, I bought two more jack stands, creeper, and a 3/8 inch torque wrench.
Old Apr 28, 2007 | 02:49 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Getting rocker rails is a good idea also to eliminate the need for pucks. Good to have for alignment racks also............
Old Apr 28, 2007 | 05:30 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
There was a post here about jacking up a C5. I took a 2x10 about 24 inches long with a 1x4 placed in front of it against each front tire.I drove the car onto it. Then take two 24 inch 2x4's stacked on top of each other, and put that on the jacking cup of the low profile jack. Align this with the cross member under the engine support, and you are good to go to lift the front end. I got a low profile 3 ton jack with 3 ton jack stands from Pep Boys for $99. The jack goes from 3 1/4 inch to 17 inches. It was still a little tight getting it under the front air dam with 2x10's, but it did work. You may try the wood ramps that are shown here on the forum on another post. Just do a search and I'm sure you'll find it.
Old Apr 28, 2007 | 06:21 PM
DBLX's Avatar
DBLX
Default Do this...
I use a scissor jack to lift to my desired height, or to get it high enough to use a standard floor jack. Cost, about 25 from Autozone.
Works like a champ.
Old Apr 28, 2007 | 07:02 PM
2KFRC5's Avatar
2KFRC5
http://www.harborfreight.com/cpi/cta...emnumber=47246
http://www.harborfreight.com/cpi/cta...emnumber=91039
I've had the #47246 for about 4 yrs. So far it's been great and flawless. I've heard of others that have the #91039 are just as happy with them.
If you have a current HF mailer, it has a coupon for an additional 15% off.
Old Apr 28, 2007 | 08:29 PM
500hp's Avatar
500hp
I just bought a nice aluminum jack at Northern Tools. It is probably similar to what is available at Harbor Freight.
It is the lowest I have seen at 3.25". It was $169, but was the nicest, sturdiest of all the 3,000 lb aluminum 'race' jacks I have seen.
My intentions are to use a 3/4" aluminum puck against the frame, within the notches of the rocker panels.
I have only lowered the rear about 1 inch.
Old Apr 28, 2007 | 11:16 PM
Misho's Avatar
Misho
great mod!
Old Apr 28, 2007 | 11:25 PM
Ralphyboy's Avatar
Ralphyboy
Harbor Freight had an aluminum 11/2 ton floor for about the same price as Pep boys.However, Pep Boys had the complete set with a steel( it is heavy) 3 TON jack with stands for about the same price as the aluminum one without jacks. The jack stands HF had were crude and horribly made .I wouldn't put my kids bicycle on them. Also, avoid ALL HF hand and power tools. They are poorly made, and don't work well. I had to return a socket set( my mistake for trying them). A real mechanic wouldn't think of using such crap ,so if you care about your car and the work you do, spend a few bucks more, to get something that works and will last.
By the way, the 3ton jack will also be better if you have a truck or SUV, which you want to work on, so its a better all around tool.
To C5 and a Low Profile Jack
Old Apr 28, 2007 | 11:42 PM
Hardcorvette's Avatar
Hardcorvette
Probably some of the best jacks/stands money can buy!
The Harbor Freight and Craftsman jacks might seem like a good deal but, in the long run, you get what you pay for. I went through 3 Craftsman before buying my AC Hydraulics...excellent investment!
Old Apr 29, 2007 | 11:37 AM
corvettefrance's Avatar
corvettefrance
I have the T1 springs and had it lower to the mini.
I never found a jack that was able to go underneath.
then I always drive on 2x4
Old Apr 29, 2007 | 12:16 PM
NoOne's Avatar
NoOne
I drive on a 2x4 for the front, rears I drive up on Rhino Ramps and then use a piece of wood to fit in the rear cross member and go up from there.
