oil pressure!!!!!!!!!
Old Oct 17, 2001 | 07:48 PM
robiferretti's Avatar
robiferretti
Default oil pressure!!!!!!!!!
Oil pressure gauge read 80!!!! Never seen that before i was in second gear slowing down at about 65 mph downhill.... What happened here , never seen it that high...HELP PLEASE? :confused:
Old Oct 18, 2001 | 10:05 AM
robiferretti
Default Re: oil pressure!!!!!!!!! (robiferretti)
Bueler?
Old Oct 18, 2001 | 10:25 AM
6Speeder's Avatar
6Speeder
Seems too high, but need more data to troubleshoot . Did DIC and gauge agree, what was the coolant/oil temps at the time, are you using recommended weight oil, did the pressure go back to normal, or stay that high, etc.
SOME cars have experienced sticking oil pressure relief valves, in the oil pump. They can stick open, giving ZERO oil pressure, or closed, giving too much pressure.
Old Oct 18, 2001 | 10:37 AM
jefffxdwg's Avatar
jefffxdwg
Default Re: oil pressure!!!!!!!!! (6Speeder)
This just happened to my SS, it jumpes up to 75 at WOT and is at 65 normal driving. It never used to be this high? Oil and filter only have 1K on them.
Old Oct 18, 2001 | 11:13 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: oil pressure!!!!!!!!! (jefffxdwg)
As mentioned above, the oil system has an overpressure relief valve that will open to prevent excessive pressure. Obviously, higher RPM will produce higher pressure. When I had mine up to 155 mph, the oil was quite warm but the high, sustained RPM gave me a surprisingly high pressure. I didn't spend a lot of time looking at the gauge, but it was at least 65 psi or perhaps higher. Normal during cruise for me, depending on oil temp, is around 50.
Old Oct 18, 2001 | 11:34 AM
Closer_2001's Avatar
Closer_2001
Default Re: oil pressure!!!!!!!!! (Gearhead Jim)
Mine hits 80 when under moderate accelleration on a cool engine in the morning.
Old Oct 18, 2001 | 03:50 PM
Y2KWS6TA's Avatar
Y2KWS6TA
I would think it would be better to have too much oil pressure than to have too litte oil pressure.
Old Oct 19, 2001 | 12:19 AM
robiferretti
Default Re: oil pressure!!!!!!!!! (Y2K_WS6_T/A)
just making sure there aren't going to be any caps popping off or anything, and she was cold...at farily hard acceleration
Old Oct 19, 2001 | 12:22 AM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default Re: oil pressure!!!!!!!!! (Closer_2001)
Ditto
Old Oct 19, 2001 | 09:35 AM
jefffxdwg's Avatar
jefffxdwg
Default Re: oil pressure!!!!!!!!! (White_98)
Is this normal or too high. The SS never used to run this high and my FRC pressure is lower???
To oil pressure!!!!!!!!!
