Check codes from Car
Old Apr 23, 2007 | 12:20 AM
Crabr1's Avatar
Crabr1
Default Check codes from Car
I can't seem to find the directions on how to check codes,can someone help
Old Apr 23, 2007 | 12:30 AM
jbauch357's Avatar
jbauch357
search does wonders - and only took a couple seconds..
The "diagnostic display" mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" , press "fuel" four times within a 10-second period.
When first engaged the on-board diagnostics go into an "automatic" mode.
The computer will show two kinds of codes, "current" and "history," designated "C" or "H". A current code indicates a malfunction is present in the system whose module is displaying data. A history code indicates a past problem.
When the screen displays "manual diagnostics," select the desired module by pressing the "options" button to go forward or the "trip" button to go back. Press "gages" to go forward or "fuel" to go back for each code under a module.
To exit the diagnostic mode at any time, press "E/M". If you want to erase or "clear" codes, press, "reset."
looks like youre local too, can show you in person one of these nights...
