Clicking Noise
Old Apr 23, 2007 | 02:39 PM
JPBabyRange's Avatar
JPBabyRange
Default Clicking Noise
Recently,whenever the engine is running on my vette, I have this click click click click noise that gets faster with the rpms. Is this the lifters? I've got 34000 on the vette and never heard this before. I know cammed LS1's like to click but I have the stock cam. Any ideas?
Old Apr 23, 2007 | 03:08 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its possible the lifters are the source. How many miles on the car? Oil need changing? Oil level low? The LS1 valve train isn't the quietest around. Did this come on suddenly?
Old Apr 23, 2007 | 03:16 PM
JPBabyRange
I've got right at 34000 miles on the car. This came on (it seemed) after I made a run at the Tail of the Dragon ( I ran the car pretty hard)
The car has no power loss at all. The noise sounds like its coming from the driver side of that engine more than anywhere.
I need to check my oil again- It was fine last time I checked
Old Apr 23, 2007 | 05:30 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would check rocker ars as they are known for the needle valves to fall out sometimes.
Old Apr 23, 2007 | 11:40 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
Sounds like a lifter isn't pumping up. I have one too. Mine will come on after a few minutes at a normal idle but go away at a fast idle or just nornal driving. When I do a H/C job I will be replacing them with a quilty up graded set.
Old Apr 23, 2007 | 11:45 PM
cmeflibi's Avatar
cmeflibi
thats funny mine is doing the same exact thing. it's really loud after a good highway drive or if the car sat out side in the cold for a little while, sounds like the thing is going to explode. Mine is coming from the drivers side head area also it seems.
Old Apr 24, 2007 | 04:18 PM
JPBabyRange
Will this cause any damage to just leave it be??- I plan on doing a H/C in the future sometime and would upgrade everything then as well.
Old Apr 24, 2007 | 05:16 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
A collasped lifter or a broken rocker arm shold be fixed sooner than later. If any parts break off you could do serious damage to your engine.
Old Apr 24, 2007 | 07:07 PM
bill mcdonald's Avatar
bill mcdonald
My Z06 is doing this as well.
drivers side head I guess.
I took off the fuel rail cover and it seemed louder.
Old Apr 24, 2007 | 09:55 PM
JPBabyRange
How big of a job is this? I doubt I would try it myself but what am I looking at $$$ wise to get this fixed?
Old Apr 24, 2007 | 10:20 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Not that bad of a job.
Pop off the FRC (Fuel Rail Cover) and then the valve cover.
Do a quick inspection to see if you can visually pinpoint problem, if not get someone to crank over your car and see if you can see any abnormal movement.
After that it's a simple remove and replacement of bad part.
Old Apr 25, 2007 | 10:45 AM
JPBabyRange
Thanks for the info- I'm gonna check it out.
To Clicking Noise
