idle relearn
Old Apr 24, 2007 | 08:16 AM
JOHN MOORE's Avatar
JOHN MOORE
Default idle relearn
What is "idle relearn"? I've noticed my '00 A4 has a little bit of a rough idle lately. Noticed it the first time as I was backing into a parking space Sunday. Tach would drop down to 500 or so, and then it would smooth out. Seem to notice it when the A/C is running, and the fan is running high. Checked the DIC, and it showed 13.5-13.7 volts at that time. Everything seemed OK at highway speeds right after that. Did it again yesterday afternoon as I was pulling into the driveway. Any thoughts?
Old Apr 24, 2007 | 09:33 AM
rws.1's Avatar
rws.1
Idle relearn is a procedure that allows the PCM to recalibrate air/fuel ratios. This procedure may be requried after changing an air intake, MAF, porting a throttle body etc.
It should norrmally not be required if no changes have been made One exception.. . ( there may be others) If you have recently changed from an alcohol free to an alcohol containing gasoline, you will have leaned out your air/fule mixture.
Idle Learn Procedure
Automatic Transmission
Perform the following procedure in order to return the learned idle to the correct position:
1] Turn OFF the ignition.
2] Restore the PCM battery feed (if disconnected).
3] Turn OFF the A/C controls.
4] Set the parking brake, and block the drive wheels.
5] Start the engine.
6] Ensure that the engine coolant temperature is more than 80°C (176°F).
7] Shift the transmission into Drive.
8] Allow the engine to idle for 5 minutes.
9] Shift the transmission into Park.
10] Allow the engine to idle for 5 minutes.
11] Turn OFF the engine for 30 seconds.
Manual Transmission
2] Restore the PCM battery feed.
5] Place the transmission in Neutral.
6] Start the engine.
7] Ensure that the engine coolant temperature is more than 80°C (176°F).
9] Turn OFF the engine for 30 seconds.
The A/C compressor kicking in and out at idle speeds puts a high load on the engine at those rpms and will affect idle speeds on most Vettes... Some with modified cams have a very rough idle and may stall with the A/C on at idle...
Old Dec 14, 2007 | 09:22 PM
1slowride's Avatar
1slowride
Default Subscribed
Making a note here before installing my Callaway Honker.
Old Dec 14, 2007 | 11:52 PM
uracowman's Avatar
uracowman
Wow I need to do this on my c5 after I installed by throttle body.I'm getting start up idles in the 1200-1500 range.2 questions though.First, when you say restore them PCM battery feed, what exactly do you mean by this?Second,what do you mean by block the drive wheels?
Old Dec 15, 2007 | 12:22 AM
Bill Dearborn's Avatar
Bill Dearborn
Driving the car for 20 miles will also get the PCM to learn new operating conditions. All the idle relearn procedure does is wipe out the old memory so you start from a scratch baseline. Have never done it even after making mods. Never noticed a problem.
Bill
Old Dec 15, 2007 | 12:48 AM
uracowman's Avatar
uracowman
Bill
did you have a larger TB installed?Mine was running great till I installed it.
To idle relearn
