I have ordered the service manuals for my 99 MN6 coupe, but haven't received them yet. I was wondering how complicated it is to adjust the clutch. I'd like to have it engage a little further from the floor. Obviously I'm not a mechanic, but I can do some work on it as long as I don't have to tear apart too much and can do the work with the car on some jack stands. Is this something that is better done by a Corvette service center? Thanks.
Thanks for the replies. I have about 53K on my car right now. I guess I'll live with it the way it is. It's not that bad, but I thought I would do some adjustment if it was possible.
It's not adjustable, however if you were to flush your clutch fluid with some fresh stuff, it would probably engage a bit higher off the floor. You've probably got some water in the hydraulics at this point, which doesn't compress as well as hydraulic fluid (brake/clutch fluid). This means the pedal has to travel further to fully release the clutch, making it dis/engage closer to the floor.
Worth a shot, it's a bit of work but it's about your only choice - other than buying an adjustable MC (which is a decent amount of $$ and even more work).
The pressure plate adjustment procedure is for adjusting the clampinf force of the clutch fingers prior to install. After install the clutch pressure plate is self adjusting. This adjustment does not control the release point, only how hard the pressure plate clamps.
On my Luk stage II I had to make sure it was adjusted to full clamp force before installing. If you don't have long tubes it can be done w/ a helper through the clutch inspection cover in the bell housing.
Flush the fluid and begin a regimin of swapping the fluid in the reservoir with fresh fluid using a syringe or a turkey baster... it will do wonders for your clutch pedal feel.
Personally I have a new clutch master w/ all my lines wrapped in header wrap and DEI cool tape (heat refelcting tape), the clutch return spring removed, the drill mod in the slave return line, ceramic coated headers, and ATE super blue fluid all to try and mitigate the skicky clutch issue inherent to a LUK designed clutch (oem mfg.)
Dayum, you did just about everything that can be done short of also installing the clutch pedal stop from Carolina Clutch.
When you get your manuals or go to Tech Tips on the forum, do the clutch hydraulics flush procedure and put in Synthetic DOT4 brake fluid. It has a higher boiling point than DOT 3 and can handle the high temperatures better than DOT 3 your clutch hydraulics undergo. If you are not comfortable with flushing your hydraulics, then do the 'poor mans' flush. Take the cap off of the clutch master cylinder, using a turkey baster remove the fluid in the resivoir making sure you don't spill any fluid it'll eat paint, wipe clean and refill w/DOT 4 synthetic brake fluid. Repeat this each day of driving for a week or so, you should see improvement providing nothing is mechanically bad. I did this and had noticible improvement. Cost me $6.00 for Valvoline Synthetic DOT 4 fluid.
Did pretty much the same thing and did feel an improvement and I also got that fluid on my paint but luckily I had just washed my car and had a bucket of water right next to me so I threw it on there very fast and paints good. Do it.
I've been reading the information on changing the clutch master cylinder fluid using this method. It sounds pretty straightforward, so I'm going to try it next week and see what happens. Thanks.
Funny you should say that ECS makes them for CC and I have on on my work bench right now
Be sure to give us some good feed-back on it if you bolt her up. I'm curious (as are many others) about the "over center" pedal travel being the main contributing factor to the "stuck pedal" syndrome.
Tnx.
