Lexan Targa Top Peeling - Help
Old Apr 24, 2007 | 03:50 PM
Don Lindeman's Avatar
Don Lindeman
Default Lexan Targa Top Peeling - Help
My Lexan top has developed a 2-inch wide bare spot on the passenger side the entire length of the roof. It almost look looks as if the first layer of material has peeled off. I did a forum search, but couldn't find anything specific to this type of problem. Anybody have any suggestions on how to fix this?
Old Apr 24, 2007 | 05:34 PM
Allan Wagner's Avatar
Allan Wagner
Im having the same problem.
Old Apr 24, 2007 | 05:38 PM
CARRJET's Avatar
CARRJET
me too
Old Apr 24, 2007 | 06:34 PM
Don Lindeman
Bizzar Do you guys have it in exactly the same area?
Old Apr 24, 2007 | 06:37 PM
DBLX's Avatar
DBLX
Default Me too!
We must be related...
Old Apr 24, 2007 | 06:59 PM
Face's Avatar
Face
It's common.
Old Apr 24, 2007 | 08:26 PM
gotvet's Avatar
gotvet
Same problem here. Not much you can do, but replace the top.
Old Apr 24, 2007 | 08:29 PM
luch90's Avatar
luch90
i wetsanded mine till it was perfectly smooth then had it cleared. from the outside it looks perfect but from the inside you can still see some of the spiderwebbing. im very happy with it versus the cost of replacement
Old Apr 25, 2007 | 08:52 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Originally Posted by Face
It's common.
It's a common problem and the General has never done anything about it.
Mine is doing the same thing. I am in the process or removing the outer coating using a Lexan lens polishing kit. It is slow going as the coating is really hard. Called GE and they say it is a Micar (sp?) coating that is baked on. Too bad that the general can't go to the sub who makes them and get them to fix them or replace them.
Once I get the thing stripped. I am going to spray with clearcoat base and a hard Dupont clear coat. I'll try to keep you all posted.
Old Apr 25, 2007 | 09:09 AM
Billdog350's Avatar
Billdog350
Keep this thread posted on the repair progress. My 1997 top is just about junk so I'd like to try the sand and clear option before giving up totally.
Old Apr 25, 2007 | 09:43 AM
Cobraboy's Avatar
Cobraboy
Is there anything that can be done to prevent this? Or at least delay it? Mine is still good (on a 2000), but it does have some minor stone chips here and there. I wondered if it is a good thing or a bad thing to wax it or protect it with some other coating. I don't want to use anything that may react with it and cause it to delaminate sooner.
What do others protect theirs with?
Rick
Old Apr 25, 2007 | 10:25 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
i gave up on mine and had it painted. of course the top is 10 years old and has enough crack in it for an entire army of druggies. Should get it bak any day. from what i've seen on the forum, painting your old and busted top usually costs about 1/2 to 1/3 the cost of a new acrylic top.
Old Apr 25, 2007 | 12:54 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
same problem here too---passenger side--I just live with it---I tell people it's from Horsepower Flex---
Old Apr 25, 2007 | 01:12 PM
Oldvetter's Avatar
Oldvetter
Rubbing a little dielectric silicone grease on it can help a lot. It is a silicone coating.
I finally gave up on my 1998 and bought a newer used one.
I will be interested in any fixes.
Old Apr 25, 2007 | 04:48 PM
hotmerc's Avatar
hotmerc
Wet sanded mine with 1500 grit & painted with PPG clear. Looks perfect from the outside, but you can just barely see the crazing from the inside. Did mine 8 months ago & it still looks great.
Old Apr 25, 2007 | 04:59 PM
jrose7004's Avatar
jrose7004
www.astrotops.com
Old Apr 25, 2007 | 05:25 PM
Don Lindeman
Originally Posted by jrose7004
The website says "Our roofs will NOT craze or peel like G.M. and other inferior panels." I wonder why GM doesn't use the same materials they use. Or even better, use Astrotops as their OEM supplier.
To Lexan Targa Top Peeling - Help
Old Apr 25, 2007 | 07:42 PM
lucky131969's Avatar
lucky131969
Welcome to the club. All of them do it eventually. The only formula to keep it from happening, is keep it out of the sun.
Old Apr 25, 2007 | 08:50 PM
jarsdad1's Avatar
jarsdad1
Yes, but does anyone know why it peels along the passenger side on all of the tops? Hot air from the S.O. relentless talking or what...?
Old Apr 26, 2007 | 04:46 AM
Don Lindeman
Was talking to my mechanic about it today. He said the worst he'd seen was somebody tried using paint remover on the roof to try and remove the glaze. He wound up painting it. Kind of defeats the purpose of having a clear roof.
