Kenny Bell BAP wiring question
Old Apr 25, 2007 | 08:55 AM
AlwaysInBoost's Avatar
AlwaysInBoost
Default Kenny Bell BAP wiring question
I'm in the process of rewiring some of the electrical stuff on my Z06 because its 'not up to code'. At the moment I'm working on the Kenny Bell BAP and you wouldn't believe how this thing was wired in, take a look at this.
What the previous 'shop' did was just stuff the 'trigger' wire for the BAP relay into the Fuel Pump relay circut.
So now that you can see what I'm working with here my first question is what position should the stock fuel pump relay be in? As you can see in the pic my stock relay is upside down (turned 180*) compared to the rest of the relays in the box and I'm not 100% sure if that is correct or not.
Does anyone have any pics of the underhood fuse panel to give me an idea? Or can just take a look at their fuse panel under the hood and confirm the position?
The next question I have is, aside from using the Racetronix harness, where are people tapping into for the trigger on the BAP relay?
Old Apr 25, 2007 | 09:02 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
this was in f/i, get power from the post next to the fuse box, ground on the frame rail, it's the grey wire in the harness with the light green tape, lingenfelter has the schematic posted on install instructions
Old Apr 25, 2007 | 10:24 AM
AlwaysInBoost
Yes Steve this was in the FI section but i didn't get much response so I figured I'd try in Tech.
I have power to the relay from that post, and ground its taken care of. What I need is the signal line from the stock fuel pump relay to the BAP relay. Is that the grey wire with light green tape you're talking about? If so I'm assuming its under the relay panel in my pic. Also can you confirm the fuel pump relay is installed correctly?
Old Apr 25, 2007 | 10:30 AM
superstockdeuce's Avatar
superstockdeuce
Here is a link to the PDF we have for the C5 boost a pump wiring.
http://www.lingenfelter.com/document...5Schematic.pdf
Hopefully this helps.
Old Apr 25, 2007 | 10:39 AM
AlwaysInBoost
Thanks that does help.
Old May 14, 2007 | 06:46 PM
Yellow03Z06's Avatar
Yellow03Z06
I am about to install mine. So the coax cable gets cut and joined. Is there no need for the dial?
To Kenny Bell BAP wiring question
