Left side headlight "flips past closed"
Old Apr 26, 2007 | 03:09 PM
FL1BY's Avatar
FL1BY
Cruise-In IV Veteran
Default Left side headlight "flips past closed"
2001 coupe. I have installed brass gears in bith headlight motors and all is working great. Then the left headlight opens fine when lights are turned on, but when turned off the headlight cover flips "past normal closed position" about and additional 30 degrees (3 inches). Is there a micro switch in the motor? What causes the motor to stop at the desired position (mechanically?) After turnign the lights off I can manually twist the left on back down, but I am tired of this. I have been drivign with the PIAA's on and don't miss the headlights, but the headlight need fixed. Any answers?
Old Apr 26, 2007 | 03:39 PM
LinearX's Avatar
LinearX
Check out this link. There is a TSB for the driver side headlight not stopping when closed. A friend of mine had this problem, and performed the TSB with just some washers. When he looked at his, though, he also had some loose bolts. Since you changed gears in your headlight motors you might want to check the bolts first to make sure they're all tight before going further with the TSB.
