Competitive Mode Problem or Operator Problem????
Old Oct 18, 2001 | 01:53 PM
rosecustom's Avatar
rosecustom
Default Competitive Mode Problem or Operator Problem????
Sorry for "gilding this lilly" but I cannot get into competitive mode. I have read recent strings about this subject and am still at a loss. I have lent my 2000 manual to a friend so I'm at a disadvantage. Anyway I have pressed and held the Traction Control button several different ways ( ie car on, just ignition on, break on etc.) and It just turns the Traction Control off and on. Thats it. The car is a y2k so I'm assuming it has AH & TC. No indication on the DIC... No Nuttin.... I hope all that the only thing wrong is that I've missed the boat.... Thanks for all your comments.............
Jeff..........
:confused:
Old Oct 18, 2001 | 02:02 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Competitive Mode Problem or Operator Problem???? (rosecustom)
You may not have Active Handling. It was not standard until 2001.
Eric
[Modified by 66ImpalaLT1, 12:02 PM 10/18/2001]
Old Oct 18, 2001 | 02:22 PM
rosecustom's Avatar
rosecustom
Default Re: Competitive Mode Problem or Operator Problem???? (66ImpalaLT1)
Eric, thanks for the response. I thought it way standard issue from 99 up. That would certainly explain it. That is a cool feature. I sure hope its still operator error. Is there a way to tell without doing some sort of a search on the vin#?
Jeff...............
Old Oct 18, 2001 | 02:28 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
Push the button and hold it for at least 5 seconds.
Old Oct 18, 2001 | 02:29 PM
HoustonC5's Avatar
HoustonC5
Jeff,
On your console, if the button is labeled Trac Ctrl (or similar) you only have Traction Control....if you have Active Handling, the button will be labeled Active Handling (or similar)....thats the quick way to tell....
mark :flag
Old Oct 18, 2001 | 02:40 PM
rosecustom's Avatar
rosecustom
Default Re: Competitive Mode Problem or Operator Problem???? (HoustonC5)
If I remember correctly ( its been a rough day so far) the button on the con has a picture of a car skidding, just like the light on the dash.
:chevy
Old Oct 18, 2001 | 05:15 PM
Mike Mercury's Avatar
Mike Mercury
The 2000 required the car to be stopped. And the button hold may take up to 7 seconds; again assuming the car has AH.
If I remember correctly ... the button on the con has a picture of a car skidding, just like the light on the dash.
There should be text printed on the console just in front of the button that says "Active Handling"
[Modified by Mike Mercury, 6:55 PM 10/18/2001]
Old Oct 18, 2001 | 09:49 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Hold the button for 5 seconds or more it should come on. You must be parked
Old Oct 18, 2001 | 10:26 PM
C5XTASY's Avatar
C5XTASY
Default Re: Competitive Mode Problem or Operator Problem???? (Mike Mercury)
Generation I Active Handling cars (late 1998-2000) may be moving when the button is first pushed, but must NOT be moving at the point of Competitive Driving engagement. In other words, you could push the button 4 seconds before you stop, so when you stop, you get Competitive Driving almost immediately. If you are not stopped at the point of timeout, you must reinitiate the entire cycle again as Competitive Driving will then not engage on this cycle. Generation II Active Handling cars (2001-2002) can engage Competitive Driving on the fly.
This is true.
This is true.
Ed
[Modified by C5XTASY, 8:31 PM 10/18/2001]
Old Oct 19, 2001 | 11:55 AM
Mike Siska's Avatar
Mike Siska
Also, if you look on your glovebox door (inside) your options will be labeled. If you have the JL4 option, you have AH/TC. :yesnod: If it's not listed, you don't.
Old Oct 19, 2001 | 01:40 PM
jawski's Avatar
jawski
yes, look in your glovebox like mike siska says. all your options are listed there.
Old Oct 19, 2001 | 05:37 PM
rosecustom's Avatar
rosecustom
Thanks to everyone for the info... Sadly it appears I do not have the AH feature. Well one thing for sure... My next one will.. Thanks again...
Jeff........
:sad: :cry
[Modified by rosecustom, 10:23 AM 10/21/2001]
To Competitive Mode Problem or Operator Problem????
