Max auto RWHP?
Old Apr 27, 2007 | 12:09 PM
vettefever17's Avatar
vettefever17
Default Max auto RWHP?
Can someone tell me what the rwhp limit is on a stock auto for a C5? I know the T56's can handle around 500 safely with no problems. I am just curious because there are more auto's on the market than manuals, as I am hunting for a C5. Also, are there any options with just adding a good torque converter and making it work? Im thinking the auto will blow out way before the manual will, that is without a build.
Old Apr 27, 2007 | 12:13 PM
Skunkworks's Avatar
Skunkworks
You may want to ask in FI section, but you do have lots of people running around with 700+ RWHP on A4.
Oh, check with RPM they are a sponsor.
Mike
EDIT on built RPM A4
Old Apr 27, 2007 | 01:06 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
I believe the a-4 is rated at 400 hp stock( Not sure if that is crank or rear wheel)
Old Apr 27, 2007 | 01:20 PM
vettefever17
Yea, I want to do a full exhaust and A&A supercharging kit the reason I ask. I should at least get 500 RWHP alone from the kit and exhaust mods.
Old Apr 27, 2007 | 02:24 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
You will need a built trans if you plan to put that power down. Most guys with 400RWHP+ break very fast with stocker.
Old Apr 27, 2007 | 02:32 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Ask EG
Old Apr 27, 2007 | 04:42 PM
vettefever17
Looks like Ill be going for a stock manual for a while. It should hold up better than the auto.
Old Apr 27, 2007 | 05:09 PM
Laguna Blu's Avatar
Laguna Blu
My stock A4 crapped out at 400 RWHP and 35K Miles (25K were with the 400 RWHP).
Old Apr 27, 2007 | 06:11 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I am 410RWHP on my stock T56, and I would not want to add any more without upgrading it. I am on the stock clutch too, and will be upgrading(clutch) this summer, I know that puppy is ready to go..on pass at the drag strip(or couple good street launches) and she's toast
Old Apr 27, 2007 | 06:26 PM
chargedc5's Avatar
chargedc5
I'm 514rwp with auto. So far so good, however I just spin my tires. Once I put drag tires on it will probably be a different story. Im knocking on wood right now
Old Apr 27, 2007 | 06:35 PM
torchvette10's Avatar
torchvette10
You may be lucky for a while but usually stock trannies don't really like blowers
Old Apr 27, 2007 | 06:53 PM
1fstc5vette's Avatar
1fstc5vette
Yea thats what I'm finding out for myself right now with my mn6 tranny
Old Apr 27, 2007 | 08:54 PM
JR_VET's Avatar
JR_VET
See all, it not the HP!!!!! it the TORQUE that is the killer that why the TQ management system is so important to GM.
Old Apr 28, 2007 | 12:56 AM
LS7 C5's Avatar
LS7 C5
I never had an any issues with my stock automatic and stock converter. I did run a large cooler on the tranny though.
I was running a Maggie supercharger on stock LS1 421 RWHP and 436 lbft torque.
Old Apr 28, 2007 | 03:26 AM
ICaughtVetteFever
Sounds like you are still on street tires then, not putting anywhere near that much power down in reality, hooking is what kills the trans, not spinning.
Old Apr 28, 2007 | 11:38 AM
Face's Avatar
Face
Broke mine with 320rwhp.
Old Apr 28, 2007 | 12:14 PM
vetfun98's Avatar
vetfun98
Ran all last year on Et Streets w/450 RWHP & 1.6 60ft No problems. I do have a trans cooler installed.
To Max auto RWHP?
Old Apr 28, 2007 | 03:14 PM
David426's Avatar
David426
Torque is the killer,, although torque and horsepower go hand in hand for the most part. 350-375 rw torque/horsepower... Thats about it.. Mine fried at 326 rw torque at 38,000 miles.. The A4 is the weak link in this drivetrain.... Transmission Temperatures over 200 degrees are the killer... Heats a killer for the A4... RPM transmissions has the best reputation for building bullet proof a4 s
Old Apr 28, 2007 | 10:20 PM
LS7 C5's Avatar
LS7 C5
Yeah, I should have added that. They were 295/35 AVS Yokohamas.
Not very good for traction.
Old Apr 29, 2007 | 09:19 AM
Mike04's Avatar
Mike04
I've ran my SC for over 2 years and about 10,000 miles with zero problems. (530rwhp with Nitto RII's)
You never know how long the tranny or rear end will hold out......
