Is this Normal?
Old Apr 27, 2007 | 05:04 PM
rally's Avatar
rally
Default Is this Normal?
Hi All.
I am experiencing vibration under hard acceleration coming from the back of the car,can this be coming from the Exhust? (Borla system)
It's being felt at the shifter and the seat,and it's severe. But only undel load over 4000 rpm.
Is this normal for a Z06?
Thank you.
Uri
Old Apr 27, 2007 | 06:00 PM
BrianG01's Avatar
BrianG01
I was going to say yes until you said severe....
Old Apr 27, 2007 | 06:04 PM
drbvac's Avatar
drbvac
Probably not the exhaust, are you getting wheel hop or spin under the hard acceleration?
Old Apr 27, 2007 | 06:35 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
Not normal. I have the Borla system but no vibrations.
Are you experiencing wheel hop? How much air pressure are you running in your tires?
How many miles on the car?
When was the last Diff fluid change?
Old Apr 27, 2007 | 07:01 PM
rally's Avatar
rally
Not weel hop, air pressure is 35 psi, 20,000 k on it.
Old Apr 28, 2007 | 02:27 AM
500hp's Avatar
500hp
Do these cars run CV joints in the rear?
If so, how do they mesh with the rear wheel hub?
To Is this Normal?
