Tech Tip for disconnecting clutch hydraulics
Old Apr 27, 2007 | 06:47 PM
jimmyz808's Avatar
jimmyz808
Default Tech Tip for disconnecting clutch hydraulics
Started to pull out my LS7 clutch last night (stupid POS clutch), and remembered that clicking the collar on the clutch line was a pain to do. I thought for a second, grabbed the nearest thing that looked like the right size, and voila.
All you have to do is grab an 18mm box end wrench, and slip the two forks of the open end up around the fitting. Then just pull the wrench back and it'll pop free. Took me all of about 3 seconds to have the thing unhooked.
Old Apr 27, 2007 | 06:58 PM
craig04c5's Avatar
craig04c5
Good tip! Thanks.
Old Apr 27, 2007 | 08:25 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
damn, that $30 tool from the snap-on truck for nothing , good tip, some of the early qd's are a pita
Old Apr 27, 2007 | 10:30 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
That is what I've been doing. Immediate disconnect without much effort.
To Tech Tip for disconnecting clutch hydraulics
