cam or headers?
Old Apr 28, 2007 | 08:53 PM
fastbluels6's Avatar
fastbluels6
St. Jude Donor '10
Default cam or headers?
should i get a cam kit first or long tubes? i dont have the money for both so im trying get what i can for now.
Old Apr 28, 2007 | 09:47 PM
1slo6's Avatar
1slo6
well a cam a nice but headers are much easier to do.... a cam will involve a tune...then u will wat more power and then u will blow the motor and go bigger and the bug never ends
Old Apr 29, 2007 | 12:50 AM
94legaleagle's Avatar
94legaleagle
My vote is for headers FIRST - reason: you will need headers to make your car breath properly with a cam - I'm thinking that doing the cam first, you might not see initial gains from the cam w/o a good set of headers to get rid of gases.
Old Apr 29, 2007 | 01:55 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
^ Not too mention the Tune which will be required after the cam install.
If you go with SS Autochrome Headers and X Pipe you might have money for both!
Old Apr 29, 2007 | 07:20 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Headers first and then some bling...
Old Apr 29, 2007 | 10:05 AM
KidCid's Avatar
KidCid
CI 7-8 Veteran
Headers first and then save up to do the engines all at once. Heads cam, underdrive pulley, oil pump, and timing chain. Saves on labor if you plan on doing this anyway, just tear down the engine once.
Old Apr 29, 2007 | 10:15 AM
02MillenniumVette's Avatar
02MillenniumVette
Old Apr 29, 2007 | 11:01 AM
Max@Cartek's Avatar
Max@Cartek
I would do headers first. As stated above you don't need a tune for that. Then when you get a cam and tune, the tune will be done for both.
1 3/4 full lengths with intermediate X-pipe.
Max
Old Apr 29, 2007 | 12:29 PM
brandtdavis's Avatar
brandtdavis
headers. The sound will make you happy you did, not to mention the hp/tq you will gain. Be careful once you start its hard to stop...383s, 402s, etc. etc. good luck
Old Apr 29, 2007 | 01:34 PM
Zosickness's Avatar
Zosickness
Headers first.
Old Apr 29, 2007 | 03:03 PM
500hp's Avatar
500hp
TSP Headers are only $750 WITH an X-pipe (maybe less, they had a GP started awhile back). You can also find used headers on here for cheap.
Also, guys are always changing to bigger cams, so there are usually several used cams for sale, as well (average about $250). These roller cams are very durable, and a used one is rarely damaged from 'normal' high performance LS engine usage. Just use common sense.
Depending on the cam you are considering, you may, of course, need springs (less than $300). I assume this is on a Z06/LS6?
Just because these are Corvettes doesn't mean you HAVE to buy a $1600 set of headers, or a $500 cam (or $600 spring kit)! Again, common sense applies, and maybe a little creativity with your research.
Wait a little longer, save a few more dollars, and do both. Then you can get a good tune and take COMPLETE advantage of both mods.
I have always believed a larger/better cam is your best SINGLE, most effective engine mod. But it is not necessarily the easiest, or cheapest. Calling it a SINGLE mod is decieving, though, since you may need springs, retainers, pushrods, etc.
Old Apr 29, 2007 | 04:30 PM
NightmareZ06's Avatar
NightmareZ06
I just finished with my cam install ($750) cam,springs,pushrods. True, you have to mget a tune($125) but the performance gain is unbeleivable, nothing that headers would give you. Good set of headers are what 800-900ish. IMO go with the cam first. Then by the time that you finally do headers, now that you have the cam, the h/p gain will be so much more!
Old Apr 29, 2007 | 04:52 PM
jordanfd's Avatar
jordanfd
KidCid nailed it. To do a cam right you need to do a lot more than just stick a cam in it. (U/D pully-timming chain-ported oil pump) Frank
Old May 1, 2007 | 08:24 PM
ThePizzaC5's Avatar
ThePizzaC5
Sure, it's not what you gave the choices for, but a differential will add giddy-up, and is close, cost-wise.
Just a thought.
Old May 1, 2007 | 08:35 PM
MUKAK's Avatar
MUKAK
cam
Old May 1, 2007 | 09:01 PM
The Wrench's Avatar
The Wrench
The decision is obvious:
Wrong Option. Get the not-too-aggressive cam, cause you don't plan on going crazy with this "modding" thing.
Then get the headers.
Then change the cam again cause it's now not enough for "mod fever".
Right Option. Get the headers - enjoy for awhile.
Think more about that "just-a-bit-bigger" cam you now want.
Install that cam and be done with it - for awhile at least.
Any arguments with this logic, "Mod-Heads"?
Cheers,
DG
Old May 1, 2007 | 11:43 PM
Tx Ray-C5's Avatar
Tx Ray-C5
Are they for sale on bay again ??
Old May 2, 2007 | 12:20 AM
NOS500's Avatar
NOS500
I'd get the Headers first, then save up for the cam and all the goodies to go with the cam. Good Luck!
Old May 2, 2007 | 08:52 AM
Pwrtrip75's Avatar
Pwrtrip75
Id put a cam in it first. Who says the factory manifolds dont flow enough? The vette manifolds are way better than the f-body ones and we put a cam only in my friends formula and it ran mid 12s through manifolds and a 3" y-pipe.
The vette has much supperior exhaust factory.
Unless your going with some .600+ lift cam, 4000+ stall, and plan on racing it all the time all you need is someone who can tune your car good and it will run good with the factory manifolds. I would lose the cats though for sure.
Headers would only make a difference in the higher RPMs and which your car is only there for a second before you shift anyways.
To cam or headers?
