First dyno session today
Old Apr 29, 2007 | 07:00 PM
BrianG01's Avatar
BrianG01
Default First dyno session today
Went to a local car show and they had a dyno there and I gave it a shot.
I have dynatech longtubes, slp high flow cats, bigger H pipe, corsa indy exhuast, and a vararam.
Seemed low to me...
Old Apr 29, 2007 | 07:01 PM
BrianG01's Avatar
BrianG01
pictures dont seem to be working...
so heres my numbers:
321/334
328/336
326/339
Old Apr 29, 2007 | 07:38 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Looks Good to Me!
It looks good to me. A stock C5 will dyno at about 300 RWHP.
I met a guy at a car show today that swore his Vararam added 50 HP. I tried to explain that it was marketing hype, but he instisted.
How does it run? I'll bet it pulls pretty good!
Bob K.
Old Apr 29, 2007 | 07:51 PM
BrianG01's Avatar
BrianG01
Bob K.
Runs great so far.
To do:
Get rid of rattles
Get tune and make sure they remove the rear O2's
Get the exhuast tips straight again (they are looking a bit crazy at the moment)
Old Apr 29, 2007 | 08:36 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
I recently Dynoed and got a tune with pretty much your same setup, The tune netted me an additional 10 RWHP...
Old Apr 29, 2007 | 08:42 PM
BrianG01's Avatar
BrianG01
have you ever run it at the track? Thats next for me after the tune and then im calling it a day.
Im curious what ill run
Old Apr 29, 2007 | 09:20 PM
viper8u2's Avatar
viper8u2
get a good tune
I got about 25 more horse with just about the same mods
Mike
Old Apr 30, 2007 | 12:45 AM
LLVETTE's Avatar
LLVETTE
Had mine dyno'd Saturday. It has LT's, stock cats, X-pipe and straight custom cat-backs with a Vortech cold air ram...
324/335 baseline
332/346 tuned
The shop had dyno'd a stock 01 LS1 at 302 HP on a previous date.
Old Apr 30, 2007 | 12:51 AM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Had mine dyno'd a few months ago:
No Tune, Vararam, orig. plugs/wires, stock headers and H pipe, Borla cat back, lots of visual mods..
Old Apr 30, 2007 | 12:54 AM
RainJ's Avatar
RainJ
I've now added Long Tube Headers, Hi-Flow Cats, and an Xpipe. (and 160 degree Tstat is on its way).
Going back for a tune and another dyno session soon.
Old Apr 30, 2007 | 01:47 AM
FUN LS1's Avatar
FUN LS1
St. Jude Donor '08-'09
I'm running what you see in my sig, a tune really helped me out.
Old Apr 30, 2007 | 02:08 AM
tstar's Avatar
tstar
Assuming you mean a 1/4 mile... that will be a first for me as well, I've never ran a "real" 1/4 mile before. There is one nearby that I just learned about and I'm going to give it a shot. No baseline run to go by though, and I wouldn't expect to see anything significant as I'm fresh meat on the 1/4 mile and it's a MN6. But I think it'll be a blast!
I'll post up afterwards and let you evperts analyse the sheet...
Old Apr 30, 2007 | 02:09 AM
tstar's Avatar
tstar
Damn Rain, those are some killer numbers for your mods!!!!!
I can't wait to see your post Header runs!
Old Apr 30, 2007 | 03:26 AM
Corvette Don's Avatar
Corvette Don
Look and my numbers in my sig, I still have stock maifolds and cats along with the stock crapy LS1 intake manifold. Those numbers kinda sound low but the track tells all
Old Apr 30, 2007 | 03:41 AM
tstar's Avatar
tstar
Ooops just saw the SAE standard.... Those numbers are friggin high !!!!!! Where's the straight pipes? Did you eliminate the H Pipe?
My SAE numbers w/Ebay Headers and tune are 337.5/34o.2
Old Apr 30, 2007 | 04:58 AM
Corvette Don
Each dyno and car is different, mine was on a DynoJet (plus I have a 2000 and my cam has a tad more lift than the others, dont know if this really helps or not), but yea overall I was happy with those #'s, I know its got to be right cause if I would of got a 2.0 60' at the track I ould have ran about a 12.8 right about where it should be, but I basically had a guy at a muffler shop (this is the 5th car I have taken to him for exhaust work he is friggin awsome) I had him cut the mufflers out (he cut after the axle) and weld in straight pipes with some bad *** dual tips ($160 for the both of them), sounds like a damn Nascar car WOT, I may have to go to TI exhaust after the headers and sell the ones I have now. Prob the best mod I have done for $200.
Old Apr 30, 2007 | 07:59 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
321/334
328/336
326/339
Your numbers look accurate Brian
To First dyno session today
Old Apr 30, 2007 | 10:23 AM
jason.fox3's Avatar
jason.fox3
I got TPIS long tubes, no cats, and corsa indy. Vararam intake and the smooth coupler. I am at 329 rwhp and 344rwtq. My best time at the track so far is 13.201..... I seem to be shifting too early, I just leave it in drive and go.
Old Apr 30, 2007 | 10:47 AM
mrm1149's Avatar
mrm1149
I started doing the same thing..Seems to actually work better. 13.2 last year in 92 degree air
Old Apr 30, 2007 | 12:24 PM
kilrb's Avatar
kilrb
If you are un-tuned, I would think you'd see another 10 easily with a tune. I ran my MN6 99 with Vararam and Z06 Ti with a best of 317 (also hit 305 and 310) at the wheel. And I know the dyno isn't an ego-booster, as my head/cam package registered in tuned at 410 on the same dyno, which is on the low-end for that setup.
Considering stock 99's run somewhere between 300 and 305, you have a good 23-28whp gain, and will most likely get another 10 with a tune. I think you are on target...
