AC is hot
Old Apr 30, 2007 | 10:05 AM
Anne's Avatar
Anne
3rd Gear
Default AC is hot
I FINALLY got my first Corvette on 4/14!!!!!!!!!!!!! Does the euphoria ever go away?? It's perfect, except that it's an automatic. Guess after waiting so long with NO vette, waiting for a stickshift while driving an automatic will be just FINE.
Anyway, the AC is hot. The dealer "fixed" it by "adding freon" - which seemed to work - and they also said they checked for leaks by running dye through the system. No leaks, they said, yet a week later when I tried using the AC again, it was hot. Sounds to me like there is a leak. No chance I could just disconnect the battery like it fixes some of those other A/C problems is there? What do you think the problem is?
Thanks, and I'm really glad to finally be among you vette owners.
Old Apr 30, 2007 | 10:22 AM
TLewis4095's Avatar
TLewis4095
Where are you located? Do a search & there are a ton of threads on this issue. If near us we can look at it no charge.
Old Apr 30, 2007 | 07:51 PM
80vetla's Avatar
80vetla
I just learned the hard way about disconnecting battery. Make sure you know the radio loc code cause i didnt and had no radio !
To AC is hot
