Clicking behind dash
Old May 1, 2007 | 01:50 PM
BrianG01's Avatar
BrianG01
Default Clicking behind dash
When I turn the car on or just turn on(either to "on" or "ignition") everything works fine from what I can tell but there is a mechanical clicking/winding noise coming from behind the gauge cluster.
I have no idea what it could be...
Any ideas?
Old May 1, 2007 | 04:05 PM
TEXHAWK0's Avatar
TEXHAWK0
Probably coming from the column lock actuator.
Has your car had any of the recalls done?
Old May 1, 2007 | 04:38 PM
GreyGT-C's Avatar
GreyGT-C
mine does the same thing... i was under the impression that it was the A/C door acutators doing their range of travel check when you switch the car on.
So who's gonna tell us what it really is?
Old May 1, 2007 | 04:42 PM
BrianG01's Avatar
BrianG01
The previous owner installed/removed something where it no longer has that
Old May 2, 2007 | 06:05 AM
BrianG01's Avatar
BrianG01
anyone?
Old May 3, 2007 | 12:41 AM
UDRIVESLOW's Avatar
UDRIVESLOW
a/c actuators make noise some times..
it will sound like a wirl with a click click click
also the ipc can make noise
try to remove the ipc fuse and re-cycle the ignition..
no noise its the ipc..
you can do the same by pulling the a/c control fuse...
hope that helps
udriveslow
To Clicking behind dash
