Removing battery, what needs reprogrammed?
Old May 1, 2007 | 08:11 PM
G8rDMD's Avatar
G8rDMD
National Champs Gators 4 St. Jude '09
St. Jude Donor '10-'11
Default Removing battery, what needs reprogrammed?
I will be unhooking my battery to install an amp and probably to also upgrade the big three in the next week or so...my question is, what will I need to reprogram once I hook it back up? DIC, memory seats, windows? Thanks for your help, I love this place
Old May 1, 2007 | 08:42 PM
nmbis2k's Avatar
nmbis2k
I switched batteries and only had to reprogram the anti-theft code in the radio. Make certain you find the code first.
Old May 1, 2007 | 09:16 PM
LarryW's Avatar
LarryW
I had my battery removed for several hours and only had to update the clock setting on the factory radio (no issues with the anti-theft code since I've never programmed it)...no other issues
Larry
Old May 1, 2007 | 09:25 PM
SUNNYD 95's Avatar
SUNNYD 95
You will also have to reprogram your key fobs.
Old May 1, 2007 | 11:41 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
I changed my battery last week and only had to reset the clock. When reconnecting power, don't be alarmed with racket that the trunk mount CD changer makes.
Old May 2, 2007 | 12:48 AM
rustyguns's Avatar
rustyguns
i did my 02 zo6 with redtop and only had to reset the clock
Old May 2, 2007 | 11:47 AM
UstaB-GS549's Avatar
UstaB-GS549
Same with mine. Battery out of car for months.
Old May 2, 2007 | 01:04 PM
BowTieRocket's Avatar
BowTieRocket
Look in your owner's manual. If you're not sure, look for a red light blinking on the stereo head unit with the key off. If it's blinking, the anti-theft is set. It's probably in the manual under "TheftLock" or some derivative thereof.
If you don't know the code, you should probably see your dealer for advice before disconnecting the battery. Per the service manual, there's a "factory backup code" that the dealer can access, but it isn't published in the manual.
The good news is that the default is no code set, and the only other effect I'm aware of is that the PCM goes into initial learning mode after being de-powered.
Old May 2, 2007 | 09:40 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
I used one of these it worked great
You can order it HERE
Old May 2, 2007 | 09:50 PM
RazrVET 02's Avatar
RazrVET 02
02 Coupe. Had battery out for two days and only needed to reset the clock.
Old May 3, 2007 | 01:16 PM
SFCA1968's Avatar
SFCA1968
I put a new battery in the other day on my 03 Z
All I lost was the clock-everything else, seats, radio channels etc
did not change or need a redo.
To Removing battery, what needs reprogrammed?
