B0333 Outside Air Temp Sensor Open, how do i fix?
Old May 2, 2007 | 05:12 PM
WRXBen's Avatar
WRXBen
Default B0333 Outside Air Temp Sensor Open, how do i fix?
Just pulling the codes from my car and saw this one. How do I fix it? Where is the sensor for it?
Ben
Old May 2, 2007 | 05:34 PM
randomus's Avatar
randomus
Its an easy fix, the sensor is up in front of the passenger side headlight under the hood. It's mounted on the frame near where the air dams connect. Its also the only wire up there.
The sensor costs less than ten bucks from a forum sponsor and takes about 5 minutes to replace. Just make sure you get the orientation the same way so the little nub points correctly.
Old May 2, 2007 | 05:35 PM
randomus's Avatar
randomus
Thinking about it, make sure the connector is plugged in all the way before you buy a new one.
To B0333 Outside Air Temp Sensor Open, how do i fix?
