superchips
Old May 3, 2007 | 02:03 AM
Tgress's Avatar
Tgress
4th Gear
Default superchips
can anyone tell me if superchips can be bad for your corvette?
Old May 3, 2007 | 03:44 AM
SLPRC5's Avatar
SLPRC5
What year Corvette do you have? It's a basic hand held tunner...there are better out there..
Old May 3, 2007 | 09:56 AM
Tgress's Avatar
Tgress
4th Gear
2003 50th Soft Top
what's available that works, and won't harm the car? and can put the vett back to stock?
Old May 3, 2007 | 12:58 PM
BlackZ06's Avatar
BlackZ06
2003 50th Soft Top
Your question implies that the car has been "tuned", and you want to return the engine management to stock.
Some thoughts:
* If the engine has been cammed, for example, then returning to the "stock" settings may not be a good option .... especially if it has an "aggressive" cam in it.
* Unless you have a list of what parameters were changed in the tune, and what the stock values are for those parameters, it will be pretty time consuming to go through and "detune" the PCM with a handheld.
* If you really want to return to stock, I'd recommend taking the car to a dealer and have them reload the PCM using a Tech2 scanner. The scanner will, based on your VIN number, select the correct software for your PCM and reload it into the car.
HTH
Old May 3, 2007 | 05:18 PM
Tgress's Avatar
Tgress
4th Gear
no, it's not tuned yet.
My question is, If I put a superchip tuner in it, I know that it will also bring it back to stock, so, if I decide to use a superchip tuner, will it harm the car in anyway?
and, if there are better one's out there for HorsePower and fuel mileage, what are they?
thanks.........
Old May 5, 2007 | 12:29 PM
BlackZ06's Avatar
BlackZ06
thanks.........
HP and fuel mileage are two mutually exclusive goals ... you want HP, you gotta burn fuel to get it. You wanna save fuel (better than stock) then you gotta give up HP. GM has spent mucho dollars coming up with a pretty good "compromise" tune for the stock PCM. Changes you make will, in almost any circumstance, be a tradeoff of HP versus MPG.
There are lots of tuning tools out there (Hypertech, Autotap, etc.). More "sophisticated" ones allow you to look at (and alter) many more parameters than the Superchips device, BUT, they also expect that you have some idea of what happens when you mess with fuel maps etc.
As far as "harming" the car ...
Be aware that in some states some "tunes" may cause you to fail smog testing, I have no idea how stringent your state's testing is, nor how "aggresive" the superchips tune is.
While it is unlikely there will be new PCM programming from GM for the C5 generation, you want to make sure your car has the "latest" PCM programming in it before using the Superchips device. For example there are updates for the PCM that are part of the "Steering Column Lock" recall campaign. If these updates have not been applied, and a dealer applies them AFTER you've used the superchips tuner, you will not only possibly loose the "tune", but also from what I recall the Superchips tuner will "lock out" from the car because it will recognize that its "stock" files no longer match the current PCM "stock" files.
HTH
To superchips
