c5 engine management replacement.
Old May 3, 2007 | 02:46 AM
peterc5oz's Avatar
peterc5oz
Default c5 engine management replacement.
Hello fellow Vet heads.
Have a 1999 covert. 6 spd.c5 in South Australia.(Try finding someone here who knows c5's ).Had ongoing problems with idle bad running etc. etc. Fitted a procharger ,mechanical throttle body and at the same time a Haltech engine management system. Lost cruise and traction control as a consequence which I am not concerned about because the car runs perfectly and goes exteremely hard. SO WHAT IS THE PROBLEM!! IS THERE ANY WAY OF STOPPING MESSAGES FROM DASH DISPLAY( THE THING IS GOING NUTS) OR DO I JUST LIVE WITH IT. I can disconnect the buzzer and remove the warning lamp globes engine , traction etc. but is there a way to interupt or stop messages ?? Is there a way to keep instruments but stop messaging ??
Thanks from down under
Old May 3, 2007 | 07:42 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I doubt it, the BCM and PCM talk to each other and it sounds like you've got the electronics cobbled together just enough to make the engine run.
The stock PCM is perfectly capable of running that engine with the supercharger, I would suggest returning the elctronics and the throttlebody back to stock to eliminate your messages.
Old May 3, 2007 | 07:47 AM
Pipedream's Avatar
Pipedream
Old May 3, 2007 | 09:33 AM
Pwrtrip75's Avatar
Pwrtrip75
Put a peice of black tape over it.
Old May 3, 2007 | 10:09 AM
SpeedyZ's Avatar
SpeedyZ
I'm assuming with the Haltech engine management system the factory PCM is gone. What may work, or help would be to put a factory PCM back in the car and hook it to the data buss. You could probably mount it under the seat, would probably need only 5-6 wires hooked up. Then at least everything would talk and be happy. Would have to study the problem for a while to see how good this idea really is, but it may solve a lot of your problems.
On the other hand, if you want to get rid of ALL the DIC messages that is pretty easy also. You should be able to simply disable it in the IPC with a little soldering. At worst simply remove the VFD and you will never see a message again!
Or like said above, take the IPC apart and put a piece of black vinyl over the VFD and you will never seen any messages again!
Is things like your odometer working correctly now? Oil pressure gauge working? Exactly which messages are you getting?
Old May 4, 2007 | 10:29 AM
peterc5oz's Avatar
peterc5oz
Thanks for your input ,
original engine management pcm is still in vehicle . ALL gauges and odometer work SO I am back to original fix.I disconnected buzzer and removed traction and engine lights .I can live with error messages.
Car does run better than ever and cable throttle body is giving better response.Injector control is superior with Haltech engine management and MAF has been removed .MAF LESS tune gives more HP.
To c5 engine management replacement.
