Does anyone know of a source for a step by step how-to r&r a stock
'00 valves? Also, should anything else be replaced while I'm in there? The motor has 96K on it. I had it dyno'd a couple days ago and got hp and torque drop of after 5500 rpm. The technician said the wavering lines indicated weak valve springs.
