Highbeams will not come on
Check the ground connection behind the headlights on the frame rail. If you have a Digital Multi Meter, you can check if the highbeams are getting power by unplugging the connector behind the headlight and seeing if the highbeam wire is getting 12V when the switch is set to highbeams. If it is, then the ground is likely the problem. If it's not, then the problem is upstream towards the headlight stalk switch.
Document ID# 562105
2000 Chevrolet/Geo Corvette
Headlamps Inoperative - High Beams
High Beam Headlamps Inoperative Step
Action
Value(s)
Yes
No
DEFINITION: High beam headlamps are inoperative, low beams are functional.
1
Were you sent here from the Lighting Systems Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Lighting Systems
2
Disconnect connector C209.
Connect a fused jumper wire in the harness side connector C209, between terminals W and K.
Do the high beam headlamps illuminate?
Go to Step 4
Go to Step 3
3
Remove one of the high beam headlamp fuses.
HDHIBML MiniFuse® #12
HDHIBMR MiniFuse® #9
Connect a DMM from the fuse terminal B in the underhood electrical center, to the harness side connector C209 terminal K.
Measure the resistance of circuit 11.
Is the resistance within specified values.
0-2 ohms
Go to Step 5
Go to Headlamps Inoperative - One Lamp
4
Replace the headlamp switch. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle .
Is the repair complete?
Go to Step 6
5
Repair the open or high resistance in circuit 11.
Go to Step 6
6
Clear any DTCs which may have set. Refer to Diagnostic Trouble Code (DTC) Clearing .
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Document ID# 562105
