AC troubles
Old May 4, 2007 | 09:00 PM
nickolbag's Avatar
nickolbag
Default AC troubles
A little problem with the air conditioning. First, last fall it blew cold air out of the drivers side and not the passengers. Now I get no cold air. I can not control the temp *****. It is stuck at 73. All other buttons work except front defroster. But once it is on it will not turn off. I have to shut the car down and even then sometimes it comes back on again. So I pulled the codes and got this....
BCM
B2578-H RF Turn Signal Monitor Circuit (Short to Voltage)
B2583-H LF Turn Signal Monitor Circuit (Short to Voltage)
SDM
B1001-H Option Configuration Error
RFA
U1096-H Loss of Communication with IPC
U1064-H Loss of Communication with BCM
U1016-H Loss of Communication with PCM
U2110-H Right Rear TPM Sensor Malfunction<---drag tires
U2215-H Left Rear TPM Sensor Malfunction<---drag tires
None of the codes were current. I cleared the codes and drove the car for a week. Pulled the codes again and B1001, U1096, U1016, and U1064 came back.
Any ideas why my AC buttons won't work? Is there an HVAC control module that can be bad? Any ideas would be appreciated.
Old May 5, 2007 | 04:45 AM
97vetteman's Avatar
97vetteman
There is a control module for the Duel Climate Control it is uder the passenger side dash.
You have to remove the panel under the glovebox and it's up in the corner behind the heater blower motor.
I replaced mine when I got my car as my blower motor was not working. The dealer had replaced my C/C display with e recon one but the display showed blower motor faster and slower but no blower. If you put a wire on the blower motor and touch it to ground that tells you if the blower is working or not. I relpaced the module with one from a Buick Regal for $25 got it on Ebay. GM dealer price is $80+ Everything works fine now.This is the part number of the one I used Blower Control Module p/n 52479971
He still has one available for sale on Ebay.com
http://cgi.ebay.com/ebaymotors/ws/eB...m=230110249302
I not sure wether or not it would cause the problem you have.
Here is what the module looks like. The duel c/c module is different to the standard a/c module just for your info
It's held in with 3 screws and it a PITA to remove
Hope this is of help to you
Old May 6, 2007 | 10:50 PM
nickolbag's Avatar
nickolbag
Thanks for the response. Now its throwing..
B0446 Right Actuator Out of Range
Now if an actuator goes bad will it cause the whole thing to get screwy? I don't see how a bad actuator would cause the buttons on the display to not work.
Old May 7, 2007 | 09:43 PM
nickolbag's Avatar
nickolbag
Old May 8, 2007 | 12:23 AM
FRC Jon's Avatar
FRC Jon
lurk
Old May 11, 2007 | 02:53 PM
nickolbag's Avatar
nickolbag
anybody?
Old May 13, 2007 | 11:22 PM
nickolbag's Avatar
nickolbag
Old May 27, 2007 | 03:15 PM
RogerArrambide's Avatar
RogerArrambide
It looks just like the normal fails in Vette....
In tech forum, you may find a post for electrical problems that Im sure will be helpfull
http://forums.corvetteforum.com/showthread.php?t=896875
Old May 27, 2007 | 03:52 PM
corvettedoug's Avatar
corvettedoug
Do a search on the forum for the actuator relearn procedure. Some have had success with doing this procedure before replacing parts.
Old May 28, 2007 | 11:32 PM
RogerArrambide
I just searched but didnt find anything about it
Old May 28, 2007 | 11:54 PM
nickolbag's Avatar
nickolbag
Did it with no sucess. I think I'm just getting actuator trouble codes because the hvac control module is bad. Why else would all the other crazy things be happening? Like the limited and unpredictable use of the AC console.
Old May 30, 2007 | 08:21 PM
nickolbag's Avatar
nickolbag
No codes. New HVAC control module changed the temp from 73 to 75-76. Nothign else seems to work right. Air doesnt blow hard. Any ideas
Old May 31, 2007 | 12:34 AM
97vetteman's Avatar
97vetteman
If you have a buddy with a C5 try putting his HVAC display unit in there to see if anything changes!
Next step may have to be the stealership!
To AC troubles
