APP Sensor 3 Circuit Performance ?
Old May 5, 2007 | 08:08 AM
Rays Vet's Avatar
Rays Vet
Default APP Sensor 3 Circuit Performance ?
Has anyone seen code 1286 app sensor 3 circuit performance before??? New to me and what is it??? Came up after a cam change. Clear all codes but this one comes back.
Old May 5, 2007 | 12:12 PM
Rays Vet's Avatar
Rays Vet
Anyone???
Old May 5, 2007 | 12:37 PM
dpd's Avatar
dpd
did you disconnect the tac module or the ground for the tac module? the ground for the tac module is above the starter on the right side.
Old May 7, 2007 | 07:29 PM
Rays Vet's Avatar
Rays Vet
No did'nt do that. But what exactly is the 1286 code about?
Old May 7, 2007 | 07:47 PM
Bill Dearborn's Avatar
Bill Dearborn
Here is what it is about:
DTC P1286 Accelerator Pedal Position (APP) Sensor 3 Performance
Circuit Description
The Accelerator Pedal Position (APP) sensor is mounted on the accelerator pedal assembly. The sensor is actually three individual Accelerator Pedal Position sensors within one housing. Three separate signal, ground and 5.0 volt reference circuits connect the Accelerator Pedal Position Sensor assembly and the Throttle Actuator Control (TAC) Module. Each sensor has a unique functionality. The APP sensor 1 signal increases as the accelerator pedal is depressed, from below 1.1 volt at 0% pedal travel (pedal at rest) to above 2.1 volts at 100% pedal travel (pedal fully depressed). The APP sensor 2 signal decreases from above 3.9 volts at 0% pedal travel to below 2.9 volts at 100% pedal travel. The APP sensor 3 signal decreases from above 3.2 volts at 0% pedal travel to below 3.1 volts at 100% pedal travel. Observe that the signal circuits for APP Sensor 2 and APP Sensor 3 pull up to 5.0 volts and the APP Sensor 1 signal circuit pull to ground within the TAC Module.
Conditions for Running the DTC
• DTCs P0606, P1517, P1518 not set.
• Ignition switch in the crank or run position.
• Ignition voltage greater than 5.23 volts.
Conditions for Setting the DTC
• APP sensor #3 disagrees with APP sensor #1 by more than 13.0% and APP sensor #3 disagrees with APP sensor #2 by more than 13.0%.
• All above conditions met for less than 1 second.
Action Taken When the DTC Sets
• The PCM stores the DTC information into memory when the diagnostic runs and fails.
• The malfunction indicator lamp (MIL) will not illuminate.
• The PCM records the operating conditions at the time the diagnostic fails. The PCM stores this information in the Freeze Frame and/or Failure Records.
• If no other TAC System DTCs are set, the TAC System operates normally. If certain TAC System DTCs are set at the same time, the TAC system commands the engine to operate in a reduced engine power mode. The TAC system may command the engine to shut down.
Conditions for Clearing the DTC
• A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
• A history DTC will clear after 40 consecutive warm-up cycles, if no failures are reported by this or any other non-emission related diagnostic.
• Use a scan tool in order to clear the DTC.
Diagnostic Aids
Important
Remove any debris from the PCM\TAC module connector surfaces before servicing the PCM\TAC module. Inspect the PCM\TAC module connector gaskets when diagnosing/replacing the modules. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM\TAC modules.
• The following may cause an intermittent:
o Poor connections: Check for adequate terminal tension. Refer to Body and Accessories/Wiring Systems for proper procedure.
o Corrosion
o Mis-routed harness
o Rubbed through wire insulation
o Broken wire inside the insulation
o Inspect the TAC module connectors for signs of water intrusion. When this occurs, multiple DTCs should set and you cannot locate any circuit or component problems.
• The APP and TP sensor 5.0 volt reference circuits are internally connected within the TAC. Inspect the 5.0 volt reference circuits at the APP and the TP sensors for an open, a ground, or a short to a voltage. TP and APP sensor DTCs will set.
• For an intermittent condition, refer to Symptoms .
• If you complete a repair and the DTC is cleared using a scan tool on the same ignition cycle, the default action will not clear until an ignition cycle has occurred.
• When the TAC module detects a problem within the TAC System, more than one TAC System related DTC may set. This is due to the many redundant tests run continuously on this system. Locating and repairing one individual problem may correct more than one DTC. Keep this in mind when reviewing captured DTC info.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
9. Jumping one APP sensor signal circuit to 5.0 volts should not affect any of the other APP sensor voltages. A problem exists within the TAC module if jumping the circuits affects another APP parameter.
10. Jumping one APP sensor signal circuit to ground should not affect any of the other APP sensor voltages. A problem exists within the TAC module if jumping the circuits affects another APP parameter.
17. When the TAC module detects a problem within the TAC System, more than one TAC System related DTC may set. This is due to the many redundant tests run continuously on this system. Locating and repairing one individual problem may correct more than one DTC. Keep this in mind when reviewing captured DTC info.
DTC P0226 - Accelerator Pedal Position (APP) Sensor 3 Performance
Step
Action Value(s) Yes No
1 Did you perform the Powertrain On-Board Diagnostic (OBD) System Check? -- Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2 Important
If DTC P1518 is also set, refer to DTC P1518 for further diagnosis.
1. Turn ON the ignition leaving the engine OFF.
2. Monitor the Accelerator Pedal Position sensor angle for the APP sensor 1, the APP sensor 2, and the APP sensor 3 using the scan tool in the TAC data list.
Are all three parameters at the specified value? 0% Go to Step 3
Go to Step 5
3
1. Monitor the APP sensor 1 and 2 disagree and the APP sensor 2 and 3 disagree parameters using the scan tool.
2. Slowly depress the accelerator pedal to Wide Open Throttle (WOT) and then slowly return it to closed throttle while stopping briefly at approximately 25%, 50%, 75% and 100% in each direction.
Does the scan tool display NO for the APP sensor 1 and 2 disagree and the APP sensor 2 and 3 disagree parameters? -- Go to Step 4
Go to Step 7
4
1. Turn OFF the ignition for 15 seconds.
2. Turn ON the ignition leaving the engine OFF.
3. Select the Diagnostic Trouble Code (DTC) option and the Failed This Ignition option using the scan tool.
4. Quickly depress the accelerator pedal to Wide Open Throttle (WOT) and then quickly return it to closed throttle.
Did this DTC set? -- Go to Step 14
Go to Diagnostic Aids
5 Disconnect the TAC Module connector containing the APP sensor circuits. Refer to PCM/TAC Module Replacement .
Are all three parameters at 0%? -- Go to Step 6
Go to Step 15
6
1. Turn OFF the ignition.
2. Disconnect the TAC Module connector containing the TP sensor circuits. Refer to PCM/TAC Module Replacement .
3. Check the harness for continuity between the APP sensor 3 signal circuit and the signal circuits for the APP sensor 1, the APP sensor 2, the TP sensor 1, and the TP sensor 2 using the DMM J 39200 .
Does the DMM indicate continuity? -- Go to Step 7
Go to Step 8
7
1. Disconnect the APP sensor harness connector.
2. Check the harness for continuity between the APP sensor 3 signal circuit, at the TAC harness connector, and all other circuits in both TAC module connectors using the DMM J 39200 .
Does the DMM indicate continuity? 0.0-5.0ohms Go to Step 11
Go to Step 14
8
2. Check the harness for continuity between the APP sensor harness connector and the TAC module connector containing the APP sensor circuits using the DMM J 39200 .
Does the DMM indicate continuity? 0.0-5.0ohms Go to Step 9
Go to Step 12
9
1. Re-connect both TAC module connectors.
3. Display the voltages for the APP sensor 1, the APP sensor 2, the APP sensor 3, the TP sensor 1, and the TP sensor 2 using the scan tool.
4. jumper the APP sensor 3 signal circuit to the APP sensor 3 5.0 volt reference circuit in the APP sensor harness connector using a fused jumper wire.
5. Monitor the APP and the TP sensor voltages using a scan tool.
Are any of these other sensor voltages affected or does the APP sensor 3 voltage not equal the specified voltage when the circuits are connected? 3.94-6.06V Go to Step 15
Go to Step 10
10
4. Jumper the APP sensor 3 signal circuit to the APP sensor 3 ground circuit in the APP sensor harness connector using a fused jumper wire.
5. Monitor the APP and the TP sensor voltages using the scan tool.
Are any of these other sensor voltages affected or does the APP sensor 3 voltage not equal the specified voltage when the circuits are connected? 0.0-0.1V Go to Step 15
Go to Step 14
11 Repair the signal circuits that are shorted together. Refer to Body and Accessories/Wiring Systems.
Is the action complete? -- Go to Step 16
12 Repair the circuit with the high resistance. Refer to Body and Accessories/Wiring Systems.
13 Check for poor connections/terminal tension at the APP sensor and at the TAC Module. Refer to Body and Accessories/Wiring Systems for proper procedure.
Did you find and correct the condition? -- Go to Step 16
Go to Step 14
14 Replace the accelerator pedal assembly. Refer to Accelerator Pedal Position Assembly .
15 Replace the TAC Module. Refer to PCM/TAC Module Replacement .
16
1. Select the Diagnostic Trouble Code (DTC) option and the Clear DTC Information option using the scan tool.
2. Idle the engine at the normal operating temperature.
3. Select the Diagnostic Trouble Code (DTC) option and the Specific DTC option, then enter the DTC number using the scan tool.
4. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this diagnostic ran and passed? -- Go to Step 17
Go to Step 2
17
Select the Capture Info option and the Review Info option using the scan tool.
Does the scan tool display any DTCs that you have not diagnosed? -- Go to the applicable DTC table System OK
Hope that is enough info.
Bill
Old May 8, 2007 | 12:39 AM
FRC Jon's Avatar
FRC Jon
interesting
Old May 10, 2007 | 06:52 AM
Rays Vet's Avatar
Rays Vet
Wow thanks for the info!!!!! I guess I have my work cut out for me....Anyone else ever had this problem????
To APP Sensor 3 Circuit Performance ?
