Clutch Issue - '99 Coupe
The car has about 45K on it, and as far as I know, it is completely stock (I purchased at 23K).
The issue I'm having is that they clutch doesnt hold at high torque. It drives ok (seems a little weak, but could just be me), but if I load it at high RPM, it slips (and sometimes chatters).
Like I said, I've been assuming that it needs a new clutch, so have just been driving it really carefully (and saving $$$).
Could this potentially be a hydraulics issue? I checked the fluid today and it was NASTY, so I was wondering if maybe I should try the turkey-baster deal to change out the fluid.
Any thoughts/recomendations from anyone?
Also, anyone in MD that has experience want to maybe take a look at it and let me know what you think - PM me - we can meetup sometime.
Thanks!!!
I actually already tried that, and it does stall. It feels like its slipping at high RPM when its in 3rd gear or higher under load. And the pedal feels mushy - there's only about an inch or so of the pedal travel when its engaging/dis-engaging the clutch. (I probly should have told you that in my first post).
Thanks again for the quick response!!
The LS6 clutch w/new master and slave will fix you up. I would recommend getting the remote bleeder also.
Bob K.
What do you mean by "accelerate in 5th or 6th" exactly. I dont mean to sound stupid - I dont think it will go from a stop in 5th or 6th, and once it gets going on the highway, I can accelerate in 5th and 6th (from 55 - 65, etc).
Is this what you mean? I'm a little confused as to exactly what you're refering to.
Thanks!
Is it even possible to bleed the clutch without dropping a bunch of stuff? I figure if I'm going to be removing stuff, I might as well just change the clutch, slave, etc while I'm at it.
I was considering just changing all the fluid, running it for the day, changing it again, and so on until it looked clean. Do you think this would help?
I guess my bigger concern is that I dont want to tear anything up, and dont want to get stranded anywhere if it goes out completely.
Thanks again!
http://forums.corvetteforum.com/show....php?t=1684338
That is the place to start.
Read my post in that thread. let me know if you have questions.
Ranger
Ranger
I'll definitely give it a shot - the fluid was awful when I looked at it today. It looks pretty straightforward, and would be nice if I could fix it with the cost of a few bottles of fluid (and an upset wife when she finds her turkeybaster in my garage with brake fluid in it.
The recomended fluid is Dot3, but would I be better off using Dot4? I have heard that it stands up to heat better, but dont want to mess anything up.
Thanks again.
Thanks again.
If the Chevy DOT4 is hard to locate, I've been using Prestone DOT4 Synthetic with good success.
Also you may want to pick up a syringe, in lieu of a turkey baster.
Ranger
I would try this and also change the fluid. I change mine on a regular basis. I use DOT 3 fluid, a fresh can that hasn't asorbed any moisture.
Bob K.
I took it out at lunch today, and went for a drive - I'm starting to wonder if I'm maybe just losing my mind.
Here's what I did...
1. Idle on a level surface, let out clutch in first - car dies (this is good - no slipping)
2. Ran through all the gears up to 85, no issues at all - never slipped, or chattered
3. 50mph on the highway, floored it in 6th up to 65mph - didnt slip, and it accelerated just fine (very slowly of course)
One thing that I did notice - it seems like at high RPM that it just stops pulling, which I guess is what made me think it was slipping. Its most noticable in 3rd, 4th (its pretty rare that I get it fast enough to run high rpms in 5th and 6th)
One other thing that I noticed was that towards the top end of 3rd, under heavy acceleration, it sometimes chatters slightly, and does it even worse if I hit a bump. It almost feels like the clutch is coming loose - like there isnt enough clamping force holding it.
Any ideas???
I'm still going to use Ranger's proceedure tonight, and extract all the clutch fluid several times, and hopefully that will help the issue where only about an inch or less of the pedal travel is engaging/disengaging the clutch - the rest of it doesnt do anything.
Thanks!!!
dead stop- pop the clutch the car stalls
1st- rev up to 5k before shift no slip
2nd- rev up to 4.5 k before shift, no slip
3rd- rev to 4.5 k before shift, no slip
4th- rev to 5k before shift, no slip
5th- shift out of 4th and hit it hard, clutch seems to stick, feels like the tranny is almost completely slipping, burnt rubber smell and does not pull worth ****
6th- feels fine
Now I can have the car in 5th at about 50mph and then accelerate and it pulls fine with no slip. This condition only happens when I rev high in fourth and shift to 5th and hit it hard on highway. Need opinions please? Thanks
Cajun
6th- feels fine
Cajun
Ranger
Ranger
ThanksCajun
So I always recommend that M6/M12 owners do shifting drills until the act of repetitive fast shifts is essentially automatic.
How to Improve Your Shifting
Some folks consider those instructions an "idiot lesson" for anyone who's driven a manual-tranny Corvette. Quite the contrary, these drills can eliminate missed shifts, save the clutch, and yield stronger acceleration.
Ranger
Ranger
Cajun
