Headlight Adjusting?
Remove round plug on the side.
Just inside the cover you will see what looks like a Torx screw driver, that is the horizontal adjustment.
Further inside and lower is another Torx, this is the vertical adjustment.
Sorry I can not remember which way to turn the adjuster to raise the lights
What he said. Once you remove remove the plugs on the headlight bezel surround it should be clear.
It works like a ring and pnion and if they are not lubes they just strip out.
Go easy. Don't ask how I know.
These things break easily and are difficult to find.
See http://forums.corvetteforum.com/show...ight+adjusters the 6th one down.
I lubed her up with a shot of WD and slowly worked it back and forth
then made the adjustment. Very easy! Thanks......
They are a little low. Thanks
