Emergency flasher
Old May 7, 2007 | 03:13 PM
Twospeed's Avatar
Twospeed
Default Emergency flasher
Can anybody tell me how to take the emergency flasher button off. I have the link on replacing the switch, but it did no go into how to take the front facia of the switch off.I don't want tp break something that I can't replace
Old May 7, 2007 | 08:16 PM
corvettedoug's Avatar
corvettedoug
I used a small flat blade screw driver and popped it off. It does NOT take much force at all to get it off. Make sure to be careful so you do not scratch anything.
After removing the cover, when you try to push the hazard relay back in the hole to remove it, that takes quite a bit of force. A quick pop should do it, just be careful not to slip and hit something else.
Old May 8, 2007 | 12:36 AM
FRC Jon's Avatar
FRC Jon
i need to know how to replace this also
Old May 8, 2007 | 02:26 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Hey guys, try this link;
http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
Old May 8, 2007 | 08:51 AM
Twospeed's Avatar
Twospeed
Corvettedoug,
Thank you.
To Emergency flasher
