Swagger #1. It could be a number of things. It sets the code if the PCM sees generator duty cycle less than 5% or at 100%. Could be problems with the generator, regulator, battery or PCM connections to name a few. I guess a start would be to check your battery connections and the condition of your drive belt since this happens when you rev the engine.
OK... I took the battery and alternator and had them tested... Both are working correctly, so battery, alternator/voltage regulator are off the table. I guess tomorrow I pull both connections to the PCM and see if there is any corrosion...
check your grounds, after that, since batt and alt. are good, check your belt, if it could use a replace ment, I highly recommend the goodyear gatorbacks. after that, i can only imagine it being the PCM.
