emission legal cam
Old May 8, 2007 | 02:34 PM
redline99's Avatar
redline99
Default emission legal cam
Hi, I just want to know what is the biggest cam you can run and still pass emissions.
Old May 8, 2007 | 03:55 PM
Switchbarrel's Avatar
Switchbarrel
Default Cam
I have no idea what your smog regulations are where you live. However, LG Motorsports claims their G5X1-E is their emissions cam.
-Rick
Old May 9, 2007 | 05:26 PM
redline99's Avatar
redline99
-Rick
It's the same as California, but seeing how little people responded, I can tell it's not worth it. Thanks again for info.
Old May 9, 2007 | 05:29 PM
Vette-Red's Avatar
Vette-Red
I have a 238/242 .609/.615 on a 111lsa and MTI told me that it is emission legal here in TX. Previous to this car I had an 03 Mach 1 w/ 4 cams and 2 "not ready system codes" and it still passed the state inspection. Hope this helps. I think that our standards are almost as strict as California.
Old May 9, 2007 | 05:58 PM
01vetter's Avatar
01vetter
General rule is something greater than -4* overlap (a larger negative number). A 224 224 114 LSA has a -4* overlap and it just passes. Go bigger and you might have problems.
Old May 9, 2007 | 06:55 PM
red88L98convert's Avatar
red88L98convert
so texas does **** exams too????
Old May 9, 2007 | 07:51 PM
SilverBulletZ06's Avatar
SilverBulletZ06
Do you have the sniffer test or the OBD-II plug in test?
If you have a sniffer, your screwed. Good luck.
If you have the OBD-II just run O2 sims, remove the cats, and have it tuned to not run codes and your fine.
To emission legal cam
