Play in the Steering Wheel
There is actual, mechanical problems, where the tie rods are worn,
and you can turn the steering wheel a little bit from side to side
and see no motion of the front tires, then there is "on center feel",
which is strictly an alignment problem, where the front wheels are
either too toe-out or too toe-in, and it just feels sloppy.
Year, miles, last time you did an alignment??
After that I'd check the tie rod ends.
or alignment. With the miles and time since your last alignment,
it could still be either one.
If you put the car up and pull the front wheels, you can pretty
easily check the condition of the tie rod ends. They should
pivot, but have some drag. If the tie rod feels loose, then
that's likely the problem. If the tie rods feel tight, then it's
probably alignment.
In theory, a good alignment shop will check the condition of your
tie rod ends before doing an alignment, since the alignment really
won't "take" if the tie rods are sloppy. And they will almost
certainly replace them for you if you discover they are worn,
since you'll need an alignment after replacing them anyway.
http://forums.corvetteforum.com/show....php?t=1696487
