12 Disk cd Player in Rear, error
Old May 9, 2007 | 03:28 PM
lougars's Avatar
lougars
Default 12 Disk cd Player in Rear, error
Just a simple question, I have just put a 12 dick cd player in the rear of 2003 vette, When cartridge is inserted its shuffles the cd's, but when I push the cd\aux button it displays disk 1 and track 0 then goes into error message. Is there a set up from the radio that has to be done? any answers
Old May 9, 2007 | 03:57 PM
jtrundle's Avatar
jtrundle
Not to be a smart@ss, but are you putting the CD in upside down?
Old May 9, 2007 | 04:05 PM
Burgie's Avatar
Burgie
Ditto=Been there, done that. Amazing how well it works when they are put in right!
Old May 9, 2007 | 04:06 PM
hotwheels57's Avatar
hotwheels57
Also, some CD players will not accept copied CDs w/o showing the error.
Old May 9, 2007 | 04:07 PM
vegasjunkie2004's Avatar
vegasjunkie2004
that's prob. the problem
Old May 9, 2007 | 04:15 PM
B-ras's Avatar
B-ras
And here I am with just the one.
Old May 9, 2007 | 04:58 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Unplug the changer and plug it back in, it resets the connection between the radio and the changer. Worked for me all the time when I had a changer.
Old May 9, 2007 | 06:34 PM
lougars's Avatar
lougars
Thank you all for the input. I have the cd's in the right way, but I will unplug and see if this may work. The cd's are not copys but the real deal, unless they were purchased from china and shipped here.
Thanks for input.
Old May 10, 2007 | 07:07 PM
shannanl's Avatar
shannanl
Mine seems to crap out every few weeks. A couple of times I had to fish out a CD that was stuck inside the player. Sometimes just pulling the CDs out and putting them back in helps. Of course at first I had the CDs in upside down. Mine hates burned CDs. I have several different brands and nothing seems to work.
Old May 10, 2007 | 07:53 PM
gpotski's Avatar
gpotski
Same trick when my XM Commander gets an err message when I switch to aux input. I unplug the input to the GM-10-Aux, replug it in, and it refinds the XM commander.
Old May 10, 2007 | 11:54 PM
Jistari's Avatar
Jistari
Take a look at the post on unlocking a radio in theft mode. I know, yours is not in theft mode, niether was mine, but after changing the battery it wouldn't let the XM radio I have plugged into the 12 CD changer input through.
Same symptoms (when I press Aux it powers up the XM and goes to Track 1 1 but no sound).
In trying the instructions for getting the radio out of lock mode the first step was to press preset buttons 2 + 3 (if i remember correctly), so I did that and poof, all was well (didnt have to follow through with the rest of the instructions, XM just started working).
Worth a try, good luck.
Old May 11, 2007 | 12:40 PM
stingray71's Avatar
stingray71
I had the same problem where the CD wasn't being ejected properly. Then the CD gets stuck and you have to reach inside the player and pull it out.
Old May 13, 2007 | 07:47 PM
lougars's Avatar
lougars
Default 12 disk cd player
Unpluged the unit and plugged it back together and the unit works perfect, thanks all for your input.
Old May 13, 2007 | 08:46 PM
torchvette10's Avatar
torchvette10
To 12 Disk cd Player in Rear, error
