Thanks, but the wiring diagrams did not work. I have messing with this for a day and a half.
No one seems to know how to wire this up...so I guess I will throw this connector in the garbage and buy the plug and play one from Pace. Should have done that in the first place!!!
I would return it and get the one from Pace Performance if that's what you want. Here's the link for the conversion http://paceperformance.com/index.asp...D&ProdID=24660. The cable is about $23. However, even though it is "plug and play" for connectivity, you will pay $$$$ to get the MAF tables reset with a tune. Your dollars, but I would recommending getting a 1000CFM nylon aftermarket MAF enclosure if you want the additional flow and keep your wiring the same. You can get it for around $150 from Breathless Performance . . . I would get the new one with the air foils, Item 100-225B. Again, this will still be negligible gain, but better than going through all the other tribulations of switching out to the 5-pin connector and Z06 MAF. In addition, you may have problems with your MAF tables if you have the 97 or 98 PCM. Just my thoughts. Have a good one.
Mike C sends
