Question: Why high flow cats over straight pipe?
Old May 11, 2007 | 10:59 PM
OMG its Jason's Avatar
OMG its Jason
Default Question: Why high flow cats over straight pipe?
Here in FL, there is no inspection, but even with the "high flow" cats, if we were to get inspected, wouldnt they still fail it do to the high amount of volume still getting through?
Is there another reason?
Old May 11, 2007 | 11:12 PM
lar66BB's Avatar
lar66BB
Default Hi flow cats
You need some back pressure and high flow cats will still give you
enough restriction for that. I have heard that straight pipes will
give off an exhaust order. Most of the high flows will pass emission
test. I know random and bassani's do. A good set of long tube
headers with the high flows are the ticket. Mufflers don't really
make that much differance, just pick the ones you like the sound
of.
Old May 12, 2007 | 12:34 AM
MUKAK's Avatar
MUKAK
of.
Old May 12, 2007 | 01:11 AM
Ryan L's Avatar
Ryan L
Minus the whole enviromental BS, the only difference is sound (louder!)
There is no difference in power either.
Old May 12, 2007 | 02:35 AM
nitrojunky's Avatar
nitrojunky
of.
You don't need backpressure, you need a decently fast moving column of air to aid in scavenging. As long as your primaries are of the proper configuration, the less backpressure, the better. Cats don't increase power, although a good set of high flow units won't reduce power much.
Old May 12, 2007 | 08:58 AM
dwestsr's Avatar
dwestsr
The positive effect on the environment is not BS. I remember what cars smelled like in the 50's and 60's as well as what the air looked and smelled like in our cities. I'm thankful for the cleaner air we have today because of the "environmental BS".
Old May 12, 2007 | 09:50 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Your kidding right? A car from now compared to a car in the 60s, the car from now puts out like 70% less emissions.
Also, do you remember the 70s when 400 HP cars were made to have emissions equipment? The power dropped to like 1/2.
CATS do their job, that is why they are covered under their own warranty by the FEDs. Look in your warranty booklet.
Not to mention leaded gas.
Old May 12, 2007 | 11:06 AM
kilrb's Avatar
kilrb
I remember seeing an article about Tony Mamo or another LS1tech vendor doing back-to-back dyno tests of high flow cats and no cats. They found like 3 or 4whp difference when taking off the cats. That's not to disagree with your statement about the drop in power in the 70's, but just to note that today's high flow cats don't cost much power.
Old May 12, 2007 | 02:01 PM
Dope's Avatar
Dope
Resident moron
I run cats just because I can't stand the stink of a car without them.
They will cost a tiny bit of power and sound but it's worth it.
Dope
Old May 12, 2007 | 03:37 PM
Pwrtrip75's Avatar
Pwrtrip75
Dope
The cats are what makes the stink. They are the first thing to get cut off all of my cars.
Ryan L's Avatar
Ryan L
By saying 'BS', I didn't mean the cats don't work. It's 'BS' to people who really don't care and will rip off all off, like myself. We don't have inspections in my state so the cats are the first thing to be removed. I like the sound, not to mention the power gained over the stock stuff.
Old May 12, 2007 | 05:01 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
With modern fuels, cars without cats will stink. It ain't the old days anymore.
Find a local Corvette club and go on a run and follow a car without cats. It will make your eyes water after a while.
I was going to go catless, in fact I spent $400 extra (!!!) to have my headers made up with a catless x-pipe in addition to the standard one with hi-flow cats. While I was waiting for delivery I drove over a hundred miles following a club member with a cammed and catless Z06. It was nasty. I'm practically an anti-environmentalist but I just couldn't do it to my fellow motorists. The $400 x-pipe makes a nice wall ornament.
Choose your choice. But running catless will stink, and no, it won't be the smell of a high-compression engine on Sunoco 260.
Old May 12, 2007 | 05:04 PM
Dope's Avatar
Dope
Resident moron
*boggle*
Dope
Old May 12, 2007 | 05:06 PM
Ryan L's Avatar
Ryan L
BTW, I wouldn't really call it a 'stink', since that implies its a BAD smell.
Old May 12, 2007 | 05:07 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
If anything, removing the CAT's cost you torque.
Old May 12, 2007 | 05:15 PM
Ryan L's Avatar
Ryan L
If anything, you should shove banana's in your tail pipes and your torque will become infinite!!
Old May 12, 2007 | 05:22 PM
Honez's Avatar
Honez
How about it's against the law! It's a federal offense to run without them and the fine starts at 10K plus you could actually be jailed for it if they wanted to press the letter of the law.
To Question: Why high flow cats over straight pipe?
Old May 12, 2007 | 06:25 PM
OMG its Jason
That is the least of my concern.
I have never heard of anyone being "jailed" only because of exhaust..
Let's not go off topic. I believe the question has been answered.
Old May 12, 2007 | 06:43 PM
B-rent's Avatar
B-rent
You asked "Why high flow cats over straight pipes?" sooo Im pretty sure they just gave you another example of why you should go to cat route and not going off topic....
Old May 12, 2007 | 07:38 PM
nitrojunky's Avatar
nitrojunky
Nope.
Zing!
But also I agree with the claim a catless car will 'stink', and I'd say I'm toward the anti-environmentalist pole. More like make your eyes water, but yeah, the smell/irritating nature of the exhaust is pretty annoying when you're sitting at a light.
I'm of the opinion that there should be a reasonably expensive tax that one could pay to legally remove emissions equipment/install whatever cam they want. 98% of the population wouldn't do it, so there would be a neglegible change in the urban pollution blanket, and gearheads wouldn't have to dread inspections.
