Throwing P0102 After Z06 MAF install?
Old May 12, 2007 | 01:58 PM
Blown-Interceptor's Avatar
Blown-Interceptor
Default Throwing P0102 After Z06 MAF install?
I know what the code is, I never got this or any codes before the Z06 MAF. Any ideas?
This is what I copied from a Stock 2002 Z06 file:
Copied MAF table
Set MAF Fail Freq to 13500
Max Delta Airflow
Is there anything I missed?
Thanks,
Jason
Old May 12, 2007 | 02:00 PM
Blown-Interceptor
Got some info.
Well, I just checked it. With the gauge display in tuners my MAF shows 1 g/sec, with the table display it shows 0.19. Even with revving the motor a little, there is no change in the MAF.
Here are some pics:
Start up A/F.
This is the connector I got:
As you can see the adapter has the straight through connectors, I did not use them. I used plug-in type connectors...not sure if that matters???
Thanks a lot!!!
Jason
