98 knock sensors
Old May 12, 2007 | 06:28 PM
Brad@RevXtremeAutoSports's Avatar
Default 98 knock sensors
I hear they are prone to false reads????? Anyone replace with 99s? Whats involved?
TIA
Brad
Old May 12, 2007 | 10:56 PM
TLewis4095's Avatar
TLewis4095
False reads are generally caused by headers, or any other sound producing component that generates a noise in or near the frequency that the sensor is designed to detect as "knock". Something as simple as a loose flywheel or TC bolt or the headers/exhaust ratteling can cause false knock. But the 98 is not known for being faulty vs any other year. Are you haveing issues on the dyno or the street with the tuner datalogging? My 98 has 166,000 HARD miles on it & have never had an issue...
Old May 14, 2007 | 10:37 AM
Can't pull timing according to a tuner in the area. They believe the knock sensors are the problem. I am 99% sure all bolts are tight as I just did the clutch and used loktite where directed and torqued to spec with a manual torque wrench. A week later re-tightened header bolts.
Left the tuner with less hp then when I went in. Not happy.
No road tune or drivability was done either. Idle is too high as well.
Money down the drain. Should have just listened to myself instad of others and continued doing all the work myself and ordered HP tuners for another 100 or so dollars. Oh well.
Old May 14, 2007 | 10:53 AM
voda1's Avatar
voda1
You may already have the newer sensor. There was a design change in 98. Coverage 1st design 97-98, 2nd design 98-04.
Old May 14, 2007 | 10:54 AM
TLewis4095's Avatar
TLewis4095
Bring it in & we will work something out for you....if we can't get it right no charge.
Old May 14, 2007 | 08:33 PM
Tracey here is the reason behind the question in addition to the tuner issue
http://www.ls1tech.com/forums/showthread.php?t=712331
I'm contemplating revisiitng my cam selection and since I am going to be there i figured I would change them out. What do you think?
Thanks Bro, and Mike has always had good things to say about revextreme.
Brad
Old May 14, 2007 | 09:12 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Greg at Antivenom just replaced both of mine when he did my oil sending unit...said my sensors were the worst he had ever seen
They are pretty cheap..about $40 each...
To 98 knock sensors
