Error Codes U1016, U1064, U1096 ???
Old Oct 21, 2001 | 04:49 PM
HIGHRPM's Avatar
HIGHRPM
Default Error Codes U1016, U1064, U1096 ???
I found these codes in the BO-RFA section. they indicate a loss of communication with the PCM(U1016), BCM(U1064), and IPC(U1096). What do these codes actually mean? I don't have any problems with the car except a reocuring C1225 (the dealer has replaced the LF speed sensor, no fix). Anyone have these codes? Also what else can be wrong that causes the C1225 every time I drive.
Old Oct 21, 2001 | 05:30 PM
whip383's Avatar
whip383
Default Re: Error Codes U1016, U1064, U1096 ??? (HIGHRPM)
Sent you an email with all the codes.
Chan :cheers:
Old Oct 21, 2001 | 05:48 PM
Robiwan's Avatar
Robiwan
Ignore the 10Xx's, a lot of people get them all the time, but nothing is really wrong. Just reset them when you want. I had a 1256 and had to have the RF spindle replace twice before it got fixed. Its the speed sensor that's bad and its an integral part of the wheel spindle so the whole wheel spindle has to be replaced. If you are still getting the 1255, I would go back to the dealer and get them to replace the spindle again.
My .02, Robi
To Error Codes U1016, U1064, U1096 ???
