Spark Plug Socket Size
Old May 14, 2007 | 10:17 PM
Choreo's Avatar
Choreo
Default Spark Plug Socket Size
Does the 2001 LS1 use a standard 5/8" Spark Plug Socket? I am looking at something like this for the killer plug on the Driver's side...
http://buy1.snapon.com/catalog/item....re&dir=catalog
I also see...
http://buy1.snapon.com/catalog/item....e=snapon-store
Also, just looking at the drivers side, would it not help to remove the AIR tubing first - looks like only a couple bolts to move it out of the way for better access - is that right?
Old May 14, 2007 | 10:30 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Yes it takes a 5/8 socket. I also removed the air tubes to give a little more room.
Old May 14, 2007 | 11:12 PM
rcs128's Avatar
rcs128
Yes, a 5/8 spark plug socket, a swivel and about 8 inches of extension will get the job done. I just used a few zip ties to pull/hold back the one vac tube and that was enough room to get that pesky #7. No need to unbolt any parts. Just be patient and take your time. It's really not *THAT* difficult.
To Spark Plug Socket Size
