Help Diagnostic Codes
Old May 15, 2007 | 08:29 PM
98 C-5's Avatar
98 C-5
Default Help Diagnostic Codes/ K-Harness
I've got some history codes stored,and I was wondering if they were related to a defective harness K (colunm Lock) problem.
Codes are Ao-LDCM B2252,B2282,B2284/A6-SCM B0851,40-BCM B2587,B2592?
Old May 16, 2007 | 07:29 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
LDCM = Left door control module
SCM = Seat control module
BCM = Body control module
The 2 BCM codes have to do with the column lock.
B2252 - is a key cyliner switch fault for the left door
B2282 and B2284 are battery faults for the left door
B0851 is a battery fault for the seat.
I don't see any problems, there are several codes that will always be present on a C5, I'd just reset them and not worry, now if you have driveability problems or you get a message on the DIC that says "service vehicle soon" then you have something that needs attention.
Old May 16, 2007 | 04:43 PM
98 C-5's Avatar
98 C-5
Thanks for your help!!
To Help Diagnostic Codes
